Looking to upgrade front brake
MotoMike
Re: Looking to upgrade front brake
Postby MotoMike » Thu Jun 16, 2011 3:08 pm
On the Ducbits site there is a set of honda front forks with an 8 inch brake and a 19 inch wheel for $125. Don't know if that is the 200mm brake Rick is talking about or not.
Also, I talked to David at Ducbits and he told me that 180mm 2LS is made to fit the ducati drum on most of our singles. it is a snug fit on the boss on the slider that keeps it from rotating. the reinforcing ribs that radiate out from the bearing on the hub need to be releived about 1/8th inch to clear the return springs. the plate has a functional scoop with a mesh screen over it and he describes it as having a racy look. He is sending me a picture. Said he is selling from his first run and the price is $400.00 the next run will be $500.
MotoMike
Postby MotoMike » Fri Jun 24, 2011 1:49 pm
Dave from Ducbits sent me this photo. it is of the 180mm 2LS brake that with minor modification as mentioned in the preceeding post should fit our Dukes. I think it does look racy if a bit crude. those sharp edges could be rounded off easy enough.
Shown here are two brakes so that you can see the insides.
Teckhardt
Postby Teckhardt » Fri Jun 24, 2011 5:44 pm
MotoMike wrote:Also, I talked to David at Ducbits and he told me that 180mm 2LS is made to fit the ducati drum on most of our singles. it is a snug fit on the boss on the slider that keeps it from rotating. the reinforcing ribs that radiate out from the bearing on the hub need to be releived about 1/8th inch to clear the return springs. the plate has a functional scoop with a mesh screen over it and he describes it as having a racy look. He is sending me a picture. Said he is selling from his first run and the price is $400.00 the next run will be $500.
Does DucBits have an idea of when they will do the production run? I might be interested in getting one.
1970 450 SCR
MotoMike
Postby MotoMike » Fri Jun 24, 2011 6:23 pm
Hi Teckhardt
I don't think I asked that question, but got the idea he would not order the next run til he depleated the current stock.
Here is his contact. He is not much of a computer guy but returns calls.
PHONE:(540)877-2001
FAX:(540)877-9747 website: www.ducbits.com
email: david@ducbits.com
Postby Eldert » Sat Jun 25, 2011 7:16 am
these brakeplates are made by Budamotor in Hungary
http://www.budamotor.hu/
i am not impressed with their work
Postby Jordan » Sun Jun 26, 2011 12:11 am
Eldert wrote:these brakeplates are made by Budamotor in Hungary
Why not? It's not well-finished like Harleys, but if it works well?
Teckhardt
Postby Teckhardt » Wed Jun 29, 2011 9:20 pm
I don't see the DucBits front brake on their site, but I do see the 2LS conversion for the 160MM rear Grimeca that I have see for sale on some sites.
Curious about the quality issue as well. :?:
1970 450 SCR
