On the Ducbits site there is a set of honda front forks with an 8 inch brake and a 19 inch wheel for $125. Don't know if that is the 200mm brake Rick is talking about or not.
Also, I talked to David at Ducbits and he told me that 180mm 2LS is made to fit the ducati drum on most of our singles. it is a snug fit on the boss on the slider that keeps it from rotating. the reinforcing ribs that radiate out from the bearing on the hub need to be releived about 1/8th inch to clear the return springs. the plate has a functional scoop with a mesh screen over it and he describes it as having a racy look. He is sending me a picture. Said he is selling from his first run and the price is $400.00 the next run will be $500.
Looking to upgrade front brake
MotoMike
Re: Looking to upgrade front brake
Dave from Ducbits sent me this photo. it is of the 180mm 2LS brake that with minor modification as mentioned in the preceeding post should fit our Dukes. I think it does look racy if a bit crude. those sharp edges could be rounded off easy enough.
Shown here are two brakes so that you can see the insides.
Teckhardt
MotoMike wrote:Also, I talked to David at Ducbits and he told me that 180mm 2LS is made to fit the ducati drum on most of our singles. it is a snug fit on the boss on the slider that keeps it from rotating. the reinforcing ribs that radiate out from the bearing on the hub need to be releived about 1/8th inch to clear the return springs. the plate has a functional scoop with a mesh screen over it and he describes it as having a racy look. He is sending me a picture. Said he is selling from his first run and the price is $400.00 the next run will be $500.
Does DucBits have an idea of when they will do the production run? I might be interested in getting one.
1970 450 SCR
MotoMike
Hi Teckhardt
I don't think I asked that question, but got the idea he would not order the next run til he depleated the current stock.
Here is his contact. He is not much of a computer guy but returns calls.
PHONE:(540)877-2001
FAX:(540)877-9747 website: www.ducbits.com
email: david@ducbits.com
PHONE:(540)877-2001
these brakeplates are made by Budamotor in Hungary
http://www.budamotor.hu/
i am not impressed with their work
Eldert wrote:these brakeplates are made by Budamotor in Hungary
Why not? It's not well-finished like Harleys, but if it works well?
Teckhardt
I don't see the DucBits front brake on their site, but I do see the 2LS conversion for the 160MM rear Grimeca that I have see for sale on some sites.
Curious about the quality issue as well.
1970 450 SCR
Users browsing this forum: Google [Bot] and 108 guests
