Fork Springs
Re: Fork Springs
Postby ducwiz » Sun Nov 16, 2014 8:23 am
What about the number of turns and the wire dia? Especially the latter has a huge influence on the spring rate ( goes with power of 4!)
amartina75
Re: Fork Springs
Postby amartina75 » Sun Nov 16, 2014 10:06 pm
Did you measure the inside of your fork tubes?
The springs might not fit, the spring tubes surely won't
The spring rate is likely higher, being likely from a heavier bike
Hope it works out for you
1966 250 Scrambler
johnavico
Re: Fork Springs
Postby johnavico » Mon Nov 17, 2014 11:52 am
Oops..... the springs vvill fit, I'm told they are 23mm dia (possibly 23.5), and the existing springs vvhich fit inside the fork tubes OK are 28mm dia. The tubes have an outvvard pointing flange at one end, vvhich I'm guessing vvill have to be machined dovvn. I don't knovv the vvire diameter, but then I don't knovv the vvire diameter of the original springs either. I might as vvell try them.
amartina75
Re: Fork Springs
Postby amartina75 » Mon Nov 17, 2014 2:44 pm
John,
If the springs are 23.5mm and not 33.5 like you said before they may be from 35mm forks like yours. It seems like a pretty small spring to use in 38mm forks, I don't know why Marzocchi would use the same size spring, but maybe they did. The eBay seller could be wrong, you can't really trust people on eBay to know exactly what they have.
1966 250 Scrambler
johnavico
Re: Fork Springs
Postby johnavico » Mon Nov 17, 2014 5:57 pm
In fact, the vendor told me 23, not 33 like I said on Saturday (too much vvine?).
johnavico
Re: Fork Springs
Postby johnavico » Mon Dec 01, 2014 11:29 am
The Marzocchi springs have arrived from UK. They are 23.5mm dia, 460mm long, 3.5mm vvire dia, 65 turns. As predicted, the flanges on the tubes are too big to go into my forks, but some simple machining vvill fix that.
Does the end of the spring vvhich is more closely vvound go at the top or the bottom?
John
Users browsing this forum: No registered users and 120 guests
