http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0590013582
i still have time to grab a bolt just honestly in my work drained head didnt think of it at the time.
oil pump/timing cover 250 monza question
miken5678
miken5678
Re: oil pump/timing cover 250 monza question
DewCatTea-Bob wrote:" what size hex is that on the clutch cover? "
____ The stock DUKE tool-kits came with a 15mm allen-head on the tip-end of a sparkplug-socket-wrench, (originally intended for the [old-style] oil-filter/drain plug-head), which will also fit that crankshaft plug-cap.
DUKE-Cheers,
Just an FYI on this for the side plug.. I special ordered a 15mm off your recommendation and it is to large.. took a while to get the tool but should have gone with the gut instinct its a 14mm... most people gave me a blank stare and what not when i said 15mm.. one guy flat out refused to admit they make them
If you have or can more easily obtain 9/16" that will cover most 14mm applications. 15mm can be a good size to own further down the road as it will do on some whitworth stuff and no 'standard' size covers it.
" Just an FYI on this for the side plug.. I special ordered a 15mm off your recommendation and it is to large.. "
____ Maybe I was wrong about the exact size of all those plugs, (been over 20 years since I last had to twist one!).
When I stated the 15mm size, I was going on a memory from the '70s when I asked a Snap-On salesman visiting the shop, if he had a 15mm allen-wrench... He didn't at the time but, brought one to me (for 6.95) the following week!
After I got it, I recall that it fit the job which I had needed it for, on DUKEs ! _ So I HAD assumed that that job must have been for that crankshaft-hole plug. _ But now that you say otherwise, I'm now thinking that the job must have been for twisting fork-tube plugs!
Please check & see if your new hex-tool fits those caps.
Sorry!
Sorry!
miken5678
hey no worries.. i thought it was actually kinda funny to say the least.. hunting down a 15mm isnt easy.. the sad fact is right after i made the purchase on ebay i was able to wedge my finger in the bolt hole and get it out... just my luck
" hunting down a 15mm isnt easy.. the sad fact is right after i made the purchase on ebay i was able to wedge my finger in the bolt hole and get it out... "
____ Well at least that tool-purchase shouldn't be as sad, once you've used it to remove/install the fork-plug/caps.
Have you tried that allen-wrench for fit in them yet?
__ And a correctly sized allen-wrench for the primary-cover cap/plug isn't really needed for when the time comes to tighten the cap/plug back into it's place, since ya can then use a 14mm bolt with nut, to simply use a hand-wrench on, for that job !
Happy Cheers,
Happy Cheers,
miken5678
http://offer.ebay.com/ebaymotors/ws/eBayISAPI.dll
i placed a bid on this hoping this is the correct one for mine.. i can withdrawl the bid however I am sure it will go above 9 dollars.. just wanted to verify its for a 250nc
" i placed a bid on this hoping this is the correct one for mine.. i can withdrawl the bid "
____ What is it? _ The link only goes to eBay, but not also to any listing !
Also, when-ever there's anything that you REALLY want on eBay, DON'T bid on it ! _ Instead, put it on your 'Watch List' , and that will help keep the price down, until you then place your high-bid during the last few seconds before the auction's end-time !
Hopeful Cheers,
Hopeful Cheers,
Hi Mike
if you are talking about item nr 190381301259 it will fit and has everything in it you need
oilpump , advance unit , contactbrakerplate and the shaft with gear on it
miken5678
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0381301259
this is the one sorry i buggered the link
I know about the last 30 second bid ordeal but sometimes I am not around to catch it and those guys that beat you by 50 cents even when you do that.. irks me but it is what it is...
I will keep my eye on this one as long as nobody on here goes after it as well
