The allen plug on the left case which allows access to the crank end for timing wheel installation. What is the proper size allen for that plug. Mine is brass and stamped Agip. Any tips on breaking it free?
thanks
Mike
case cover plug.
kmev
Re: case cover plug.
14mm. Soak with penetrating oil for awhile, and a little bit of heat from a propane torch (heat the case around the nut) always helps.
MotoMike
Kmev
Thanks, will give it a go.
Mike
Mike
Users browsing this forum: No registered users and 94 guests
