Hi one and all,
Grateful to be part of the forum!
I have purchased a1970 250 scrambler. It came (as a non runner) with a 350 barrel and head, is this arrangement ok?
Any thoughts are much appreciated.
250 Scrambler Head swap
Re: 250 Scrambler Head swap
We need more info! You cannot run a 350 barrel on a 250 unless it is cut down, is that the case, or is the engine fitted with a 350 Crank?
Beltandbraces
Thanks for that Colin, interesting!
I got a ‘spare’ barrel with the bike which is shorter.
I will measure both barrels.
ID a barrel is simple : 250 has 8 fins . 350 9 fins and 450 10 fins
but like always there is one exception : the square barrel 350 mototrans has 10 fins .
Beltandbraces
Thanks Eldert
In that case I have a 250 and a 350 barrel!
Heads interchange between 250 and 350.
Beltandbraces
The bike came with the 350 barrel fitted, piston seized.
The 250 barrel was a spare.
Any advantage performance wise in using the 350? If indeed I can, some contradictory info above!
I think the OD of the cylinder sleeves differ, where they fit inside the crankcase hole.
Measure these three.
The taller 350 cylinder needs a longer vertical bevel drive shaft than the 250.
