250 Scrambler Head swap
Beltandbraces
Postby Beltandbraces » Sun Oct 06, 2024 9:34 am
Hi one and all,
Grateful to be part of the forum!
I have purchased a1970 250 scrambler. It came (as a non runner) with a 350 barrel and head, is this arrangement ok?
Any thoughts are much appreciated.
Re: 250 Scrambler Head swap
Postby Duccout » Sun Oct 06, 2024 4:12 pm
We need more info! You cannot run a 350 barrel on a 250 unless it is cut down, is that the case, or is the engine fitted with a 350 Crank?
Beltandbraces
Postby Beltandbraces » Sun Oct 06, 2024 7:14 pm
Thanks for that Colin, interesting!
I got a ‘spare’ barrel with the bike which is shorter.
I will measure both barrels.
Postby Eldert » Sun Oct 06, 2024 7:27 pm
ID a barrel is simple : 250 has 8 fins . 350 9 fins and 450 10 fins
but like always there is one exception : the square barrel 350 mototrans has 10 fins .
Beltandbraces
Postby Beltandbraces » Sun Oct 06, 2024 9:39 pm
Thanks Eldert
In that case I have a 250 and a 350 barrel!
Postby Jordan » Mon Oct 07, 2024 6:45 am
Heads interchange between 250 and 350.
Beltandbraces
Postby Beltandbraces » Mon Oct 07, 2024 7:24 pm
The bike came with the 350 barrel fitted, piston seized.
The 250 barrel was a spare.
Any advantage performance wise in using the 350? If indeed I can, some contradictory info above!
Postby Jordan » Mon Oct 07, 2024 7:58 pm
I think the OD of the cylinder sleeves differ, where they fit inside the crankcase hole.
Measure these three.
The taller 350 cylinder needs a longer vertical bevel drive shaft than the 250.
