Hi
The 250 single parts diagram shows a compression spring on the steering damper rod.
Where, exactly does this go? Not where the diagram shows right under the top nut?
thanks
David
Steering damper spring
kaysystems
1967 Narrowcase 250
2004 Ducati ST3
2004 Ducati ST3
r6ymy
Re: Steering damper spring
Yes, under the top nut. There should be a sort of circlip on the shaft near the top nut that the spring compresses against. I improvised with a metal sleeve loctited in place to stop the spring
I think it's an anti-rattle spring.
kaysystems
Thank you - I've been missing that circle for years. Now it makes sense
David
David
1967 Narrowcase 250
2004 Ducati ST3
2004 Ducati ST3
Take extra care to ensure the knob is tight on the shaft ( nutlock?) and there is a splitpin below the friction assembly ,otherwise it can all fall into your wheel. Been there ,done that. very exciting.
Yes me too
kaysystems
Yes, I lost the split pin. The first time was 45 years ago!
I assume the 'circlip' is like a star washer that is just pushed on, as there is no groove for a traditional circlip. I bought my bike in 1974 and have never had a circlip - I've never needed a steering damper either!
David
David
1967 Narrowcase 250
2004 Ducati ST3
2004 Ducati ST3
Users browsing this forum: No registered users and 154 guests
