Steering damper spring
kaysystems
Postby kaysystems » Fri Apr 15, 2022 11:32 am
Hi
The 250 single parts diagram shows a compression spring on the steering damper rod.
Where, exactly does this go? Not where the diagram shows right under the top nut?
thanks
David
1967 Narrowcase 250
2004 Ducati ST3
r6ymy
Re: Steering damper spring
Postby r6ymy » Fri Apr 15, 2022 12:23 pm
Yes, under the top nut. There should be a sort of circlip on the shaft near the top nut that the spring compresses against. I improvised with a metal sleeve loctited in place to stop the spring
Postby Jordan » Fri Apr 15, 2022 12:56 pm
I think it's an anti-rattle spring.
kaysystems
Postby kaysystems » Fri Apr 15, 2022 1:25 pm
Thank you - I've been missing that circle for years. Now it makes sense
David
1967 Narrowcase 250
2004 Ducati ST3
Postby Bevel bob » Sat Apr 16, 2022 5:35 am
Take extra care to ensure the knob is tight on the shaft ( nutlock?) and there is a splitpin below the friction assembly ,otherwise it can all fall into your wheel. Been there ,done that. very exciting.
Postby graeme » Sat Apr 16, 2022 7:27 am
Yes me too
kaysystems
Postby kaysystems » Sat Apr 16, 2022 7:46 pm
Yes, I lost the split pin. The first time was 45 years ago!
I assume the 'circlip' is like a star washer that is just pushed on, as there is no groove for a traditional circlip. I bought my bike in 1974 and have never had a circlip - I've never needed a steering damper either!
David
1967 Narrowcase 250
2004 Ducati ST3
Users browsing this forum: No registered users and 181 guests
