Correct plug, Mototrans Elite
Geordie
Postby Geordie » Tue Jan 25, 2022 6:03 pm
My Mototrans Owner's Manual lists a Firestone F20 EF-S spark plug. Now defunct, I can't find a cross-ref for an equivalent.
The bike came with a new/good Champion L86C but shows rich running wherever I have the carb needle height - UB24 with spec needle/jets as originally fitted.
I am wondering if its a hotter plug needed. Its a '61 engine with big valve head and '1' cam. I don't intend high revs operation.
Any plug equivalent or suggestions gratefully received.
Re: Correct plug, Mototrans Elite
Postby Duccout » Tue Jan 25, 2022 6:10 pm
I think that a B6HS or B7HS is recommended.
Geordie
Postby Geordie » Tue Jan 25, 2022 11:05 pm
Thanks for that. I have looked for a reference,before asking here but didn't find one. As the current plug is hotter than those two, i'll have to weaken the mixture and try that.
Postby ducwiz » Wed Jan 26, 2022 11:59 am
The spanish parts catalog for the Mototrans 200 lists a BOSCH 225 (or equivalent Champion, no grade quoted).
The italian catalog recommends a 240 grade for the 200.
EDIT: I found a spanish user manual on one of my harddrives. It says "F 20 EF-S (240 on BOSCH scale)".
Postby themoudie » Wed Jan 26, 2022 6:28 pm
Aye Geordie,
According to this online cross-reference, linked to below; the Bosch 225 plug, NGK equivalant plug is the B7HS and the Bosch 240 plug, NGK equivalent plug is the B8HS.
Spark_plug_cross_reference_link
At present I am running a B7HS in my '72 450 MKIII, rather than the often recommended B6HS that appeared too hot.
I believe Nigel Lacey runs either B7HS or when possible B8HS plugs in the race engines. He may care to comment?
Paul O
Postby Paul O » Wed Jan 26, 2022 8:44 pm
Hi George,
Mine has a NGK B7 HS, you know the rest lol
Geordie
Postby Geordie » Wed Jan 26, 2022 10:38 pm
Wow, what a response. Thank you to all. I'll get a new plug and start from there.
Geordie
Postby Geordie » Fri Jan 28, 2022 9:04 am
Confusingly, I now find, NGK temperature reference numbers reduce for hotter while other manufacturer's increase!
Postby themoudie » Fri Jan 28, 2022 10:52 am
That was my problem as well Geordie. Nigel suggested that I should be running B7HS or B8HS, rather than the B6HS that I had gravitated to, as this latter heat range plug was the type recommended in the Champion to NGK conversion tables. I too thought that I was using a cooler plug, whereas in fact I was using a hotter plug and starting to get blistering on the central electrode ceramic insulator.
Postby Ventodue » Fri Jan 28, 2022 11:05 am
