Compression Release
frankfast
Compression Release
Wanted - Compression release mechanism for 350 Ducati single. I have the proper valve cover but lack everything else.
Re: Compression Release
Hi Frank
there are 2 types . 1 for the 350 Sebring with screw type adjuster rockerarm . the other one is the widecase type with winkle cap adjustment rockerarm . you can shorten the pin on the widecase valve lifter to be used on the Sebring
frankfast
Mine is the Wide Case. I'm not sure if the valve covers are the same on both the Sebring and the Wide Case but mine has the attachment on the valve cover that accepts the mechanism.
frankfast
Have everything I need except the cable. I think that I will have to make it unless I can find one.
Users browsing this forum: No registered users and 25 guests
