Compression Release
frankfast
Compression Release
Postby frankfast » Tue Oct 05, 2021 4:36 pm
Wanted - Compression release mechanism for 350 Ducati single. I have the proper valve cover but lack everything else.
Re: Compression Release
Postby Eldert » Tue Oct 05, 2021 8:13 pm
Hi Frank
there are 2 types . 1 for the 350 Sebring with screw type adjuster rockerarm . the other one is the widecase type with winkle cap adjustment rockerarm . you can shorten the pin on the widecase valve lifter to be used on the Sebring
frankfast
Postby frankfast » Tue Oct 05, 2021 9:33 pm
Mine is the Wide Case. I'm not sure if the valve covers are the same on both the Sebring and the Wide Case but mine has the attachment on the valve cover that accepts the mechanism.
frankfast
Postby frankfast » Sat Oct 09, 2021 5:43 pm
Have everything I need except the cable. I think that I will have to make it unless I can find one.
Return to “Classifieds: Ducati Parts/Accessories wanted or for sale”
Users browsing this forum: No registered users and 14 guests
