MB v UB Dellorto
Paddy
MB v UB Dellorto
Postby Paddy » Sun Mar 27, 2016 10:02 pm
What is the difference between MB and UB Dellorto carbs ? I seem toi remember MB's were used on 2 strokes but i cant see why that should really make a difference ?
TIA
Paddy
Harvey
Re: MB v UB Dellorto
Postby Harvey » Mon Mar 28, 2016 12:11 am
The Dellorto for a two stroke has a shroud around the front of the needle jet.
Harvey.
Paddy
Postby Paddy » Mon Mar 28, 2016 9:08 pm
Is it fixed or an addition ?
Harvey
Postby Harvey » Tue Mar 29, 2016 1:26 am
You can push it out and fit the flush type, that the 4 stroke use.
I had a 41mm 2 stroke version on a 360 Bulltaco, and changed the brass piece with the shroud to the flush one, to fit to a 450 desmo.
Harvey.
Paddy
Postby Paddy » Tue Mar 29, 2016 4:36 am
OK cheers for that, i wonder if that is the only difference then between an MB and a UB.... Seems odd to change the designation on the body because of a removable addition ?
Harvey
Postby Harvey » Tue Mar 29, 2016 11:51 pm
The accelerator pump was blanked off, had a choke, may have been others that I don't remember, but that was all I did to have it run well on the 450.
Harvey.
Paddy
Postby Paddy » Wed Mar 30, 2016 8:11 am
I think we are talking cross purposes here
The dellorto 1960's UB24 i have has no accelerator pump, neither does the MB24 i have , they are prehistoric :) Most 450s were running VHB or PHF in the 1970s ?
Postby Eldert » Wed Mar 30, 2016 8:19 am
the only Ducati with a PHF was the 239 sold in France
Paddy
Postby Paddy » Wed Mar 30, 2016 5:46 pm
Yes i had a 239 for a while with a PHF30, a lot of them ended up over here as they didnt sell well in France., you would surprised how many 350 and 450 are running about with PHF 36s on :)
jbcollier
Postby jbcollier » Sun May 15, 2016 4:17 pm
Not an expert but I thought the MA/MB carbs came first and the UA/UB carbs were the next development.
As to 2T vs 4T, it is not just a matter of atomizers and shrouds, the atomizer air bleed is different as well.
Users browsing this forum: No registered users and 146 guests
