What is the difference between MB and UB Dellorto carbs ? I seem toi remember MB's were used on 2 strokes but i cant see why that should really make a difference ?
TIA
Paddy
MB v UB Dellorto
Harvey
Re: MB v UB Dellorto
The Dellorto for a two stroke has a shroud around the front of the needle jet.
Harvey.
Paddy
Harvey
You can push it out and fit the flush type, that the 4 stroke use.
I had a 41mm 2 stroke version on a 360 Bulltaco, and changed the brass piece with the shroud to the flush one, to fit to a 450 desmo.
Harvey.
Paddy
OK cheers for that, i wonder if that is the only difference then between an MB and a UB.... Seems odd to change the designation on the body because of a removable addition ?
Harvey
The accelerator pump was blanked off, had a choke, may have been others that I don't remember, but that was all I did to have it run well on the 450.
Harvey.
Paddy
I think we are talking cross purposes here
The dellorto 1960's UB24 i have has no accelerator pump, neither does the MB24 i have , they are prehistoric
Most 450s were running VHB or PHF in the 1970s ?
the only Ducati with a PHF was the 239 sold in France
Paddy
Yes i had a 239 for a while with a PHF30, a lot of them ended up over here as they didnt sell well in France., you would surprised how many 350 and 450 are running about with PHF 36s on
jbcollier
Not an expert but I thought the MA/MB carbs came first and the UA/UB carbs were the next development.
As to 2T vs 4T, it is not just a matter of atomizers and shrouds, the atomizer air bleed is different as well.
Users browsing this forum: Google [Bot] and 76 guests
