What carb set up?
JJJ12345
What carb set up?
I need help with a good carb/manifold set up. '64 Monza frame, '64ish scrambler motor. No carb or manifold on the motor when I bought it. Mikuni ? What size? Thanks to all.
pear0
Re: What carb set up?
For a 250 engine - a Mikuni VM 26 would work. Stock jetting to start .
Don't know about a manifold. Make one? TomA
pear0
Manifold -- Guzzino has some
Amal carbs need no manifold, just an insulating spacer.
Studs on the head are spaced so the carb can be directly attached.
Spanish Ducatis used them.
JJJ12345
Ok thanks for the info.[img][/img] Fits pretty close to the valve cover.
If that's your bike, suggest you lose the bolts, and install studs in the head, with nuts to retain the carb.
It's more likely than studs to cause problems, and looks wrong.
You can space the carb from the head to your liking (assuming you can get the spacer), and figure out the length of the needed studs.
JJJ12345
Might be hard to see, but those are studs .
Sorry, thought it looks like a bolt head with a Torx socket in it - I've seen those.
JJJ12345
No problem. Someone may have cut them off a bit?? Bought the motor in a box. Then bought a roller. Just trying to piece it together. Fun stuff. The carb is a 627 Amal 2 stroke. Just wanted to see if it would fit. I will find a right hand 626 and give it a try.
JJJ12345
Has anyone tried running a 26mm pwk keihin?
Users browsing this forum: No registered users and 37 guests
