What carb set up?
JJJ12345
What carb set up?
Postby JJJ12345 » Wed Oct 21, 2015 10:36 pm
I need help with a good carb/manifold set up. '64 Monza frame, '64ish scrambler motor. No carb or manifold on the motor when I bought it. Mikuni ? What size? Thanks to all.
pear0
Re: What carb set up?
Postby pear0 » Thu Oct 22, 2015 3:33 am
For a 250 engine - a Mikuni VM 26 would work. Stock jetting to start .
Don't know about a manifold. Make one? TomA
pear0
Postby pear0 » Thu Oct 29, 2015 2:47 am
Manifold -- Guzzino has some
Postby Jordan » Thu Oct 29, 2015 7:52 am
Amal carbs need no manifold, just an insulating spacer.
Studs on the head are spaced so the carb can be directly attached.
Spanish Ducatis used them.
JJJ12345
Postby JJJ12345 » Thu Oct 29, 2015 11:19 pm
Ok thanks for the info.[img]
[/img] Fits pretty close to the valve cover.
Postby Jordan » Fri Oct 30, 2015 8:27 am
If that's your bike, suggest you lose the bolts, and install studs in the head, with nuts to retain the carb.
It's more likely than studs to cause problems, and looks wrong.
You can space the carb from the head to your liking (assuming you can get the spacer), and figure out the length of the needed studs.
JJJ12345
Postby JJJ12345 » Fri Oct 30, 2015 10:07 pm
Might be hard to see, but those are studs .
Postby Jordan » Sat Oct 31, 2015 4:14 am
Sorry, thought it looks like a bolt head with a Torx socket in it - I've seen those.
JJJ12345
Postby JJJ12345 » Sat Oct 31, 2015 10:59 pm
No problem. Someone may have cut them off a bit?? Bought the motor in a box. Then bought a roller. Just trying to piece it together. Fun stuff. The carb is a 627 Amal 2 stroke. Just wanted to see if it would fit. I will find a right hand 626 and give it a try.
JJJ12345
Postby JJJ12345 » Tue Nov 03, 2015 3:45 am
Has anyone tried running a 26mm pwk keihin?
Users browsing this forum: No registered users and 125 guests
