Silver Shotgun wiring harness?
Re: Silver Shotgun wiring harness?
Postby machten » Thu Jan 06, 2011 1:50 pm
Sheesh!!!!
I had no idea that a question about my Shotgun harness would go viral!
An amazing wealth of know how on this board. AWESOME!
I'm with bamnfi. As a newbie here, I'm going down to the store room to pull out the old physics text books for a mature age refresher course!!
[EDIT} I totally agree with him. This forum has been a fantastic find for me too. Thanks to you all. [END EDIT]
Re: Electronic-Ignition on a 350
Postby Jordan » Fri Jan 07, 2011 2:12 am
" I'm under the impression it had points originally. "
____ So do you think it's an Italian-Duke (not Mototrans) then?
I don't know, except it's supposed to be the last (1974?) model, with the big bottom end bearing. Is there a way to confirm country of origin?
" It went well for thousands of miles, but eventually started to misfire, "
____ What carb.model do you have on it?
Presently, a remote float type SSI29 (for the period styling). I had a VHB29 on it earlier.
I don't think it's a carburettor problem, but it's been so long ago I can't remember why I came to that conclusion.
Re: Electronic-Ignition on a w-c 350
Postby DewCatTea-Bob » Fri Jan 07, 2011 3:32 am
"" Is there a way to confirm country of origin? "
____ Yes, there's a number of clues, usually the Mototrans have "Made in Spain" cast onto various motor parts.
What type of compression-release does your 350 have? - Valve-cover type ?
" Presently, a remote float type SSI29 (for the period styling). I had a VHB29 on it earlier. "
____ Those SSIs can contribute to an assortment of annoyances, you should make sure that your issue remains even with the happier 'square-slide' Dellorto.
I assume you've already eliminated the spark-plug & cable as contributors.
Postby Jordan » Fri Jan 07, 2011 4:24 am
When I bought the bike in bits, it came with no head, cylinder or piston. I fitted a Desmo head. I haven't noticed a Made in Spain anywhere, except on the Motoplat electrics that I bought and fitted later. Does the method of compression release identify origin?
Pretty sure I would've done that. Good idea to refit the VHB temporarily. It works better, but the SSI looks better!
I put some photos in the Photos Gallery section. It's dusty and neglected, but much loved and will be recommissioned one day.
Postby DewCatTea-Bob » Fri Jan 07, 2011 11:01 am
" I fitted a Desmo head.
____ Where did you find the head & other top-end parts?
" Does the method of compression release identify origin? "
____ Well, the Mototrans 350s use the method-type which directly bleeds the combustion-chamber (similar to a 450R/T).
" I put some photos in the Photos Gallery section. "
____ I managed to find all 11 (even though they weren't actually within that section)... Nice pix of a very fine looking DUKE !
DUKE-Cheers,
Postby Jordan » Fri Jan 07, 2011 12:13 pm
DewCatTea-Bob wrote:____ Where did you find the head & other top-end parts?
Oh, just in rubbish bins and skips :)
I had about 6 singles, all widecase, and collected some bits in my travels - wreckers, private sales etc.
DewCatTea-Bob wrote:Nice pix of a very fine looking DUKE !
Thanks Bob.
Postby DewCatTea-Bob » Sat Jan 08, 2011 1:40 am
" Oh, just in rubbish bins and skips "
____ I just thought that you might've been one of those few buyers who paid over 700-bucks for a 350-DESMO head on eBay last year.
DESMO-Cheers,
grapes
Postby grapes » Sat Jan 08, 2011 3:37 am
On E-bay, there are 2 new nos wide case complete wiring harness. for 250,350,450 scr, second type for 6coil alt with electronic ign. comes with wiring diagram. 119.00$ each,plus 24.00 shipping.Item #320639870328 . Capt Paul
bamnfi
Postby bamnfi » Mon Jan 10, 2011 7:47 am
grapes wrote:On E-bay, there are 2 new nos wide case complete wiring harness. for 250,350,450 scr, second type for 6coil alt with electronic ign. comes with wiring diagram. 119.00$ each,plus 24.00 shipping.Item #320639870328 . Capt Paul
Yep, saw them Captain. Been told they are not suitable for the Shotgun :(
Looking at sites to buy bits to make my own. Lots of fotos before and after so the bleeding thing will still run. Crosses fingers! :?
Postby DewCatTea-Bob » Thu Jan 13, 2011 2:20 am
" Looking at sites to buy bits to make my own. Lots of fotos before and after so the bleeding thing will still run. Crosses fingers! "
____ Not to worry Bam, if you wish for any confirmation of which wire goes where, I can set you straight with that. _ As wire-harness building for various DUKE-models has been quite a fun endeavor for me many times in the past !
__ As you work to complete your very-own harness-project, is it your intention to use proper wire-gauges & colors, (as I hope!) ?
