Thx Bob hope your feeling better!
Yesterday I went to really great electronics store in torrance. No frills but they were quite knowledgable and stocked with supplies. I picked up all the wiring supplies including a suitable relay.
A relay for the horn you say? Same situation as the ignition. In another words what will the relay be doing for the horn?
The warning lights are the pigtail variety i think, but must confirm when I get home.
For the front brake light switch, someone suggested I can use one off a norton commando, which I think I have, or is there a better option.
Looking forward to some crimping in the near future, thx Rob
1965 ducati narrow case
Re: 1965 ducati narrow case
[quote= flanker ...
" I picked up all the wiring "
____ Good-quality electrical-wire possesses a greater number of finer wire-strands which softly flex and don't remain rigidly bent as left, whereas cheap-wire rather has fewer/thicker individual strands which are stiff & brittle. _ So I recommend avoiding the cheap-stuff !
" A relay for the horn you say?
what will the relay be doing for the horn? "
____ It's fairly commonly known that high-amperage horns overtax standard horn wire/connection circuitry, and-thus are apt to benefit from more direct current sources which std.type horn circuitry doesn't have to offer.
So by having a relay supply just the horn-itself with rather direct-connections to the pos.battery-post & ground, the horn-button & fuse & related extended wiring are then all bypassed so that those relatively wasteful horn-circuit hoops&jumps can't impede the then independent current-flow which actually powers-up merely-just the horn itself ! _ That way, the horn-button and all it's rather extended wiring only needs to handle merely-just the vastly reduced amperage of just the relay itself, (which is quite likely less than 5% of the current conducted by a std.horn).
Mechanical-type HORN-relays specifically employ electrical-contacts which more easily conduct the high-current drawn by high-power horns !
__ I could modify the horn-circuit of the latest master-diagram to reflect the wiring-scheme that would be more suited for a high-amperage horn (with or without a horn-relay). _ Then you could later decide whether the additional step of including a horn-relay is really actually-necessary for your particular high-power horn. _ However without inclusion of the horn-relay, the horn-button would then be activatable without the key-switch being turned-on. _ (I-myself see such a keyless-feature as being rather desirable,, cuz then that-way, if someone [like kids !] are messing-around with your Duke, they're fairly apt to try-out pressing the handlebar-button and consequently sounding-off the horn, thus-then likely scaring them away and/or alerting you to the fact that someone is messing-with your Duke !)
" The warning lights are the pigtail variety i think, "
____ If they only have a single-wire pigtail, then they're the physically-grounded type and-thus have limited use !
" For the front brake light switch, someone suggested I can use one off a norton commando, "
____ A front brake-cable (with b.switch) of a newer Mototrans Duke-model, would be a straightforward fit.
" Looking forward to some crimping "
____ If you post a pic of your crimping-tool, I may then have some insightful comments to offer.
flanker
Bob I uploaded 2 crimper tools that I own. One is just the regular off the shelf and the other is for barrel connectors! thx Rob
flanker
here are the "idiot lights" Ive managed to acquire! thx rob
Preferred Wire-terminal Crimping-tool
[quote= flanker ...
" I uploaded 2 crimper tools that I own. "
____ Thanks for posting pix of both the best & worst examples of wire-terminal crimping-tools !
__ I'd advise avoiding use of the cheap-one which crimps with merely female indentationing !
However the good-one which appears to 'crimp' by pressing a male-protrusion in-towards a female-recess, is the superior type of crimping-tool that I'd recommend !
__ My experienced advice for using these best examples, is to avoid pressing the male-tip into the area of the terminal-shank where the C-shape of the shank-seam/split is located. _ In other-words, always take-care to arrange the protruding-tip of the crimping-cavity so that it places it's single crimping-indentation 180-degrees around oppositely away-from the terminal-shank's split-seam. _ That way, a rather neat & firm grip of all the wire-strands is better accomplished !
Enlightening-Cheers,
Varied Indicator-lamps
[quote= flanker ...
" here are the "idiot lights" Ive managed to acquire! "
____ Thanks for the pic.
__ Somewhat unfortunately, none of them are the more useful type which can be rather universally connected-up to any circuit-type,, as they're dependent-on their 'physical-ground' circuit !
However they can still be used with most of your indicator-circuits, (except for the 'Ignition Warning' lamp-circuit).
__ For your one indicator-circuit that really requires both wire-leads,
doesn't your stock headlamp still contain it's charging-indicator tube-bulb holder (which doesn't have any ground-connection) ?
flanker
How about these Bob?
flanker
These are the ones that were on the bike since I've had it....
[quote= flanker ...
" How about these Bob? "
____ That pair of pilot-lamps are also dependent on their physical-ground in order to have a workable power-circuit !
" These are the ones that were on the bike "
____ Those two are obviously not the same.
Your bottom-left example is certainly not stock, however it appears to have both of it's circuit connections separately available from ground,, so if it carries some-kind of light that can be powered-up by your battery, then it's what you'll need for your 'Ignition Warning' indicator-circuit.
The last pilot-lampshell appears to be part of a stock-pre'66 indicator-setup, but I don't know for-sure whether it was originally intended to work with the charging-indicator or the parking-light or the high-beam*idiot-light (* which it's remaining red-tint may've been meant for).
__ How many indicator-lamps do you intend to make-use of, altogether ?
____ I'm left to assume that you don't have the stock headlamp along-with it's stock internal-parts still left intact. (?)
__ Does the 12v.light-bulb you acquired fit your headlamp okay, and is it of the type that's compatible with a parking-light setup ?
flanker
Bob some answers to your questions:
1. How many indicator-lamps to make use of
I went back to your wiring diagram and it shows: main beam warning, charge light, Ignition warning. So 3 is the answer, unless I have overlooked something. I see another light connected via a white wire from the lighting switch and I assume that is the parking light???
2. I have the stock headlamp. Ordered a new rim replacement as the stock was beyond repair. Its the 150 mm bigger light, that I think went with the 1965 monza 250. What I took out of the inside (minus the 2 indicator lights see previous photo) is shown in the photo below. I believe the the parking light is attached to the white bulb holder. An amazing note (at least I think it is) the 6v battery pictured is stamped 1965. So it could be the original but who knows... The other bulb is a 12v and fits nicely.
3. I may have to search out an ignition warning light. The one you indicated in my picture looks beat up.... Its yellow. I understand now it needs both circuit connections to function.
Thx Rob
Thx Rob
