rear wheel bearings
tonyduc
Re: rear wheel bearings
Postby tonyduc » Fri Jul 16, 2021 8:51 pm
Duccout wrote:Hi Alex,
The internal spacer is a 'top hat' type, which slides inside the cush bearing, and the spacer that fits between the cush bearing and the swinging arm measures 15 x 25 x 13.5.
Is the 15 x 25 x 13.5 spacer 25 mm in length ? That’s just about the distance between the Cush bearing and the swing arm. But 15 mm OD would be to small to fit snug with the seal.
1967 Ducati 250 MK3
1976 Moto Guzzi T3
Former:
1969 Ducati Scrambler yellow
Postby Duccout » Sat Jul 17, 2021 8:19 am
No, 15 id, 25 od, and 13.5 length.
tonyduc
Postby tonyduc » Sat Jul 17, 2021 10:48 am
Duccout wrote:No, 15 id, 25 od, and 13.5 length.
Great thanks for the info. Since the distance between the Cush bearing and the swing arm is about 25mm on my bike, I was thinking that I should fabricate another spacer as above but extends the length to 25mm. There should not be any open axel, yes ? I am thinking also that perhaps also my swing arm is bent outward.
1967 Ducati 250 MK3
1976 Moto Guzzi T3
Former:
Postby Duccout » Sat Jul 17, 2021 11:54 am
The problem is that the spacer between the swinging arm and the cush drive determines the chain line, so the only real way to get it right is to check that your swinging arm is straight, if not get it straightened, then assemble the rear wheel assembly with both sprockets in place and check the chain line with a straight edge.
