Replacement Bearings
Re: Replacement Bearings
Postby Eldert » Wed Feb 16, 2011 1:05 pm
Bob , are you having a senior moment ?
a ceramic bearings is something entirely differend as a polyamide caged bearing .
as for how they hold up : Mick Doohan had ceramic mains in his Honda . i dont know if they where
full ceramic or Hybrid bearings
the cost is holding me off
Postby Bevel bob » Sun Feb 20, 2011 9:27 am
Senior moment?? , It does happen, but not this time!.
tricolormonster
Postby tricolormonster » Mon Feb 21, 2011 7:11 pm
Ok then. next question.
Who makes the best bearings (Non-ceramic) in "your" opinion. (by "your" I mean anyone with an opinion)
NSK? SKF? FAG? Some Others?
I'm about to start sourcing bearings so it's relevant info for my future purchasing needs.
stu
Postby Bevel bob » Mon Feb 21, 2011 9:13 pm
If you buy from a bearing specialist the discounts will allow you to get the best.
3564cam
Postby 3564cam » Sat Feb 26, 2011 9:39 pm
I have a personal experience of ceramic bearings.In the Porsche 996 engine there is an intermediate shaft that is chain driven off the crank.This shaft then drive the cams by a double row chain.The bearing that supports this shaft at the flywheel end fails prematurely.It has a steel cage.Porsche fitted a bearing with a metal seal so it was starved of oil.They then went to a plastic,maybe polyamide cage but this failed as well.There is a company in the US called L&N engieering that supply a repiar kit which has ceramic ball.We have fitted many of these to failed engines with no more issues.The down side though is cost but compared to a new engine which is over £10,000 it is a well spent upgrade.
Users browsing this forum: No registered users and 106 guests
