DewCatTea-Bob wrote:Have you yet checked to make-sure the stator-cavity IDs are the same for both rotors ?
Just checked them, yes they are the same.
____ Sorry for taking so long to get back to this !basketcase wrote:I have read some of the threads on hear about changing the wiring to accomplish this, But they are lengthy and go into alot of theory, and use terms that I have heard, but am not familiar with.
I am quite capable of soldering and wiring......but there would have to be step by step directions with diagrams for me to accomplish this. If there is a thread already here like this, please let me know.
Thanks for all your responses Bob.
DewCatTea-Bob wrote:____ It would be orderly to learn what colors are the 4 wires within the wire-cable you're sure you're going to use for the job (so that some reasonable-logic can be pre-applied for the connection-installation).
So you ought to then have a fair selection of good-quality heat-shrink insulation-tubing.
DewCatTea-Bob wrote:"Be sure to first check to make-sure your selected wire-cable can be suitably fitted through/within the motor-casing cable-passageways.
__ I now understand that you're not actually getting a wire-cable with four independently-colored wire-conductors housed within a common-conduit/jacket-sleeve. _ But rather just a few individual lengths of conductor-wires with colored-insulation (in four separate colors). _ Is that now correct ?
DewCatTea-Bob wrote: In any case, the conductor-wiring which you choose should-NOT be of a SINGLE-strand type, but rather a MULTI-strand type,, and with the FINER-stranded type being most preferable.
DewCatTea-Bob wrote:So NOW, I gather that you intend to construct your-own alt.cable,, is that your actual intention ?
If so, do you then also have a source for a jacket-sleeve/cable-conduit to route-house your four separate colored wire-leads ? -Bob
DewCatTea-Bob wrote:Well, while silver-solder may-not be suitably required for this job, I would choose to use a solder-blend which contains less lead, if available. -Bob
Users browsing this forum: No registered users and 226 guests
