450 mark 3 with screw rocker adjusters
machten
Re: 450 mark 3 with screw rocker adjusters
Postby machten » Tue Feb 19, 2013 10:23 am
Hi Graeme,
My 450 has a solitary "B" only. No other marks I can see.
Kev
Postby graeme » Tue Feb 19, 2013 11:09 am
2 74 springer cases with just B and 2 74 desmo cases with BF, I wonder why they were stamped like that when the DM450 and DM450D is already different?
machten
Postby machten » Tue Feb 19, 2013 11:18 am
Even more than that, the Mark 3 is stamped DM450M3 on the left hand case.
Kev
Postby graeme » Tue Feb 19, 2013 12:08 pm
Ive Never seen that before,,, interesting.
machten
Postby machten » Tue Feb 19, 2013 1:42 pm
That's always been standard behavior for the Mark 3 widecases as far as I know. My 68 250 Mark 3 desmo is the same, but it has "C20" stamped on the LHS case.
Kev
Postby LaceyDucati » Wed Feb 20, 2013 9:41 am
Those type of stamped letters and numbers appear on heads, barrels and cases. As far as I can make out they are fairly random over the years and models, C20 appears a lot as does B and 8. A quick look around the workshop reveals C27, C32, C55, E5.... As the numbers don't get higher the newer the castings get, my guess is they are not casting batch numbers. I just presume they are inspection stamps during manufacture. Maybe they are the individual inspectors number. If that's true all we need to do is work out which inspector is responsible for passing the the poorly machined out of spec bits I've come across :-)
Best Wishes Nigel
Postby graeme » Wed Feb 20, 2013 11:46 am
Hello Nigel,
Lots of C's on 450 heads, I figure Cynthia 50 did the bevel shims, Cheryl 55 did the rockers and Olive checked the lot. (she didn't get a number stamp, just an O.
Probably similar to a paint spot today.
Early 450 cases 69/70 didn't get any stamps that I can see.
ps. sorry to sidetrack your rocker question Kev.
Users browsing this forum: Majestic-12 [Bot] and 70 guests
