widecase center stand length
amartina75
Postby amartina75 » Mon Oct 15, 2012 10:09 pm
will someone please measure their center stand and tell me how tall it is. i need to know the difference in length between the scrambler and a roadbike.
mine measures 9 1/2 tall from the bottom of the feet to the top of the pivot tube. it will not work on my 450 scrambler it doesnt reach the ground looks like its an inch too short.
the shocks are 12 1/4 long
thanks
1966 250 Scrambler
motormike
Re: widecase center stand length
Postby motormike » Wed Oct 24, 2012 6:03 pm
Hello.. I have a 70' Jupiter.... stone stock... tonight I'll visit it.. (storage)... get some date and get back tonight.. Mike, MN
amartina75
Postby amartina75 » Thu Oct 25, 2012 1:36 am
thanks, i look foreward to finally getting some information. according to the parts book and guzzino they made different lengths and i am not sure if mine is a shorter one or longer one.
1966 250 Scrambler
motormike
Postby motormike » Thu Oct 25, 2012 1:50 am
From the approx center of the swingarn shaft to the bottom of the swing arm... 11 1/4 inches. I also have a 70' 350 Scambler.. that was missing the centerstand when I purchased it... so after I scored a centerstand from a not so local cycle boneyard (250 miles round trip)... I installed it :) and found it was short... :( so I took a section of heavy steel pipe.. cut to the same width as the bottom of the stand... cut and removed a section between 10 and 2 (clock face) and welded.. since this was not a show piece.. it worked... Hope that helps... :)
amartina75
Postby amartina75 » Fri Oct 26, 2012 8:58 pm
thanks for the info, so just to be clear you measured your modified center stand?
i have no problem doing what you did and welding a piece in to make mine longer, i just want to know why i need to do it first. i would like to know how long a scrambler center stand is VS say a mk 3
thanks
1966 250 Scrambler
motormike
Postby motormike » Fri Oct 26, 2012 11:21 pm
That is the stock length for my 1970 450 Jupiter.... I only added (welded) a section of steel pipe to the 1970 350. I'll try and post a photo later. :)
amartina75
Postby amartina75 » Fri Oct 26, 2012 11:53 pm
ok, thanks i guess mine was off my dads MK3 and not his scrambler, mystery solved. i will decide what to do about it later, i hate to cut up something if i don't have to.
thanks for checking on that for me.
1966 250 Scrambler
joe46ho
Postby joe46ho » Sat Oct 27, 2012 6:55 am
I am measuring 12 1/2 " from the center of the shaft to the end of the leg on my w/c scr kickstand
Too many projects to list...
12 Ducati singles currently
motormike
Postby motormike » Sat Oct 27, 2012 10:03 am
You shouldn't have to cut the center stand... just add a section of steel pipe... and later even that can be removed if needed.... Since this is Minne-cold-DUH I'm move'n all of the toys to storage this weekend and will be able to take a photo prior to winter slumber. I'v noticed that the photos on this site download very large and even cuts off half of some of them... ideas..?... :)
motormike
Postby motormike » Sun Oct 28, 2012 9:58 pm
Image This is a shot of how I added a section on heavy steel pipe... it was better then cutting the legs and add'n material. Also the section of pipe can be removed easily if needed. :)
Users browsing this forum: Majestic-12 [Bot] and 91 guests
