...hey guys, I have a 450 engine in a 250 scrambler. I am getting close to the first start up. I have a question on the carb. The carb is a Dellorto, and as the number VHB29AD stamped on it.
First, I wanted to verify, that this is indeed the correct carb for the engine. Also, what should the jetting be? I have the stock header with a generic 'dunstall' canister/exhaust. The exhaust has no baffle.
Additionally the carb has no filter on it, and I am planning on adding a pod of some sort. I am assuming I will get better streetability from a pod than a vstack that is wide open.
Any info ya'll can pass along is appreciated. Thanx!
450 single carb question...
lumbee
71 250 Scrambler
6x 160 Monza Jr.
6x 160 Monza Jr.
Re: 450 single carb question...
on these pages
http://www.ducatimeccanica.com/parti_di_ricambio/pages/partidiricambio0335.htm
and
http://www.ducatimeccanica.com/singles_carb_set_up.html
you will find the desired information.
Without air filter and with open exhaust, the main jet should be 135 or 140.
on these pages
and
By: lumbee...
" I have a question on the carb.
I wanted to verify, that this is indeed the correct carb for the engine. "
____ All 350/450 wide-case models (except Sebring) came with that same carb.model beginning late-1968/early-1969.
" what should the jetting be? "
____ Where were YOU when this thread -(click link below) was posted this past month ?
viewtopic.php?f=3&t=1186
amartina75
1966 250 Scrambler
Just to confuse you, here's another (hopefully useful) page:
http://www.ducatimeccanica.com/67-70_si ... ual/4.html
