Are these cases salvageable
Haggis
Postby Haggis » Sun Sep 23, 2012 3:23 pm
Has anyone experienced the problem in the picture attached. It looks as though the kickstart support boss has failed, presumably because of some over enthusiastic kick starting. The bottom half of the boss has snapped off (( picture has ben taken "upside down" incase the resolution is not good enough to see.
Are the cases salvageable? I don't know anything about welding.
I have managed to get some replacement cases, so these would become spare if they were salvageable.- I am not anticipating needing them but it seems that there is so much enthusiasm for Ducati singles that it would be a waste to bin them if they are salvageable.
As an aside, are there any guides on sizes of attachments? I have been reducing them from about 2 Mb. -
Any comments very welcome.
Chris
When all else fails, read the manual.
Re: Are these cases salvageable
Postby Jordan » Sun Sep 23, 2012 10:40 pm
That looks very fixable. A good welder will build up the missing portion, and milling operations will restore the bore/face.
The challenge is to do the boring accurately. Before welding, a fixture should be arranged to locate the casting on the milling table. The existing hole provides location, not easy once it's welded. A fixture might be a dowelled plate with a removable machined bar for the hole.
For forum type use, I use a graphics program to reduce image size to something like 800x600 ish DPI, and compress as JPG at about 70%. Irfanview is very quick at this job.
Postby double diamond » Mon Sep 24, 2012 5:24 pm
Pretty common failure and repairs have been made. Usual problems with welding an oil saturated casting. After welding, you can put the clutch cover back in place and indicate the bore off the kickstart shaft hole in the clutch cover. If that's all that is wrong with the cases, they're well worth keeping. Matt
Haggis
Postby Haggis » Tue Sep 25, 2012 12:15 am
Thanks Jordan.
Although I have replacement casings it might be better to use the originals. I will ask if anyone locally can weld the cases. My main concern was that the boss is in a high stress zone and I didn't want stray lumps of metal rattling around the cases. It is pretty reassuring that Matt says this is a common failure and repairs have been made. - I am a bit baffled about why the boss failed in that place given that the shaft is supported between the back of the boss and the outer cover. One of life's little mysteries.
I will investigate further and report back. Thanks guys.
Chris.
Haggis
Thanks Jordan.
Chris.
Postby Jordan » Tue Sep 25, 2012 5:12 am
Matt's suggestion on bore location sounds like a goer.
DesmoDog
Postby DesmoDog » Sat Oct 06, 2012 2:11 am
Been there, done that. Mine was the result of a less than brilliant moment tearing the engine down, but I have heard they can/do break in use.
Here's a post-fix picture
It's worked fine ever since though I have to admit the bike doesn't see much use.
Haggis
Postby Haggis » Mon Oct 08, 2012 8:17 pm
Thanks Craig.
I have found someone who thinks they can weld the cases. Do you remember much about how it was done? - Better if I can pass info on to the guy who is doing the work. I will take the other suggestions from earlier replies as well.
Chris.
DesmoDog
Postby DesmoDog » Tue Oct 09, 2012 9:42 pm
Sorry but I don't really know much about the specifics on this. I sent it off to Rich Lambrechts and he did the welding/machining for me. I assumed he indexed the bore off the back of the hole but never put much thought into it. He may well have a template to do it from the front for all I know.
Hmm... that might not be a bad idea for when I rebuild my 350 - bring the bare cases in to work and have the holes mapped out on a CMM, it'd be pretty easy to make a jig from that info...
Users browsing this forum: Google [Bot] and 84 guests
