450 scrambler resto parts 2
3564cam
Postby 3564cam » Thu May 10, 2012 10:43 pm
Hi ,
Some more progress made on my bike this week.Got the bottom end built now ready to fit to the rolling frame.Summer riding here I come :D
Site Admin
Re: 450 scrambler resto parts 2
Postby JimF » Fri May 11, 2012 4:20 am
It's moving along quickly and clearly not at the expense of quality.
I like the Porsche mat too.
vt450scr
Postby vt450scr » Fri Jun 22, 2012 10:58 pm
Hey there 3465cam...
Your resto looking very fine, and hope it comes along well.
I'm doing one up also, but have some detailing problems with the front hub assembly. Does the width of your hub assembly equal the distance of the mounting points on the forks at the axel?
I'm thinking these dimensions should be the same, without the need to shim, or take up slack with shoulder on the tommybar. I have 3~4mm of space to take up. I believe I have the correct
brake plate and drum/hub (12 ribs supporting the bearing tube), however, there are two different P/Ns for the speedo drive plate (one for the street models, another for the SCRs).
If you get an opportunity, and assuming your hub assembly fits snugly in the forks, would you measure and reply/e-mail the length of the bearing support tube in your speedo drive plate? Mine measures 28mm.
Hope your SCR goes together w/out any snags, and oh, I've got a square case engine on the garage bench myself ('75 860GT). Just needs time, and the dreaded big funds for that one.
Thanks, and as you guys say, Cheers,
Cliff
bigsby2010@hotmail.com
Users browsing this forum: Boxprod and 107 guests
