Making A Little Progress (with pics)
guzzijon
Re: Making A Little Progress (with pics)
OK, I'll check that next. Thanks again for all of the information!
1963 (early) 250 Scrambler project
1964 250 Monza project
1981 Moto Guzzi Monza
1983 Moto Guzzi LeMans III
" I'll check that next. "
____ Still waiting to hear-of what you found.
____ Although less likely to stay unaltered, another difference between the two motor-models is that the Monza came stock with a 17-tooth drive-sprocket whilst the other motor employed a 18t front sprocket.
So which sprocket your Monza has could be of interest, along with the mileage on that Duke.
guzzijon
Trying to Find Out If It's a Monza
OK, I checked and found that there are just two wires within the conduit for the alt. cable. I couldn't tell you the color because it's all too degraded. I even peeled back the conduit more towards the middle and I couldn't tell what color. But bottom line, just two wires.
It is also missing the front sprocket and I have no idea of the mileage, no gauges on this thing. It was turned into a dirt bike a long time ago, ridden hard and then left in a backyard with caked-on mud for 30 years.
So it's looking like it's a Monza that someone added the big-valve, big port head to then?
Re: Trying to Find Out If It's a Monza
" I checked and found that there are just two wires within the conduit for the alt. cable. I couldn't tell you the color because it's all too degraded.
But bottom line, just two wires. "
____ I gather then that they were both the same shade, and therefore must have been the most common yellow wire-lead pair.
" So it's looking like it's a Monza that someone added the big-valve, big port head to then? "
____ Yes, pretty-likely the original Monza bottom-end along-with the complete M1/Mk3 top-end which you removed from it.
Content-Cheers,
Content-Cheers,
guzzijon
double diamond wrote:Wonder if it has a Mk3 cam as well? IF the cam lobes are symmetrical it's likely a stock cam but if they're asymmetrical it's something else. What are the valve sizes? Matt
I got the cam out of the head that came on the Monza last night. There is a red paint daub on it. Does this indicate a MK3 cam?
Camshaft Identification for Mk3-models
" I got the cam out of the head that came on the Monza last night. "
____ Is that the same Monza that was determined to have a Mark-3 top-end on it, (or am I mixed-up with some other) ?
" There is a red paint daub on it. Does this indicate a MK3 cam? "
____ The real/original 'Mark III' camshaft was the one with red-paint (spotted on the threaded-end of it's shaft). _ Whilst the 'Mark-3' & the Mach-I camshaft was with a gray-paint mark.
In either case, the paint-mark is rarely left it tact (within a fairly well used engine).
Got any pix of that cam ?
__ So to help tell if your top-end is a stock/untampered-with set, we need to know what size it's valves are,,
is the intake-valve 40 or 36mm ?
guzzijon
Hi Bob, yes this is the 1964 mystery bike (probably Monza) that came with the big-valve, big port top end on it. It has the 40mm intake valve, 36mm exhaust valve and the 29mm intake port. I will post pics of the cam tonight.
" It has the 40mm intake valve, 36mm exhaust valve and the 29mm intake port. "
____ As I recall, that top-end had the high-dome piston with the larger cut-outs intended for that valve-set size, so all THOSE details indicate you have the Mark-3/Mach-I type top-end EXCEPT your "red" camshaft ! _ As the camshaft that's original to that top-end is the GRAY-cam.
guzzijon
Monza cam identification???
Here's a picture of the camshaft showing the red paint dab:
Here's a picture of the camshaft showing the lobe profiles:
Here's a picture of the top of the (stuck for now) piston:
Top-end Parts Identification
" Here's a picture of the camshaft showing the red paint dab: "
____ That's not where the factory-placed identifying paint-color is located on the camshaft !
I have no idea what that red-stuff is doing (where it is) on your cam, (as it shouldn't be there!).
__ Do you have a pic showing the shaft-end where the threads are ?
" Here's a picture of the camshaft showing the lobe profiles: "
____ It's not easy to be certain but, that appears to be the gray-cam (rather than the red-cam).
" Here's a picture of the top of the (stuck for now) piston: "
____ Okay, it now seems I've confused your piston with another, as that's not the same piston I was thinking of...
As that's a MC-piston and not EITHER stock-type high-dome Borgo-piston.
Users browsing this forum: No registered users and 103 guests
