rebuild gear selector box
Re: rebuild gear selector box
Postby wcorey » Sun Mar 18, 2012 4:28 pm
...it is my understanding that when you cut a coil off a spring you make it stiffer.
Yes and no. The shorter one will be stiffer (relative to the amount of travel/compression) but in this case the spring is contained in a set amount of space so shortening it creates less preload so less force applied.
...it is not my intention to gain a reputation for being contrary...
Many of us here have contrary tendencies so you should fit right in ;)...
Postby Eldert » Tue Mar 20, 2012 2:17 pm
here is a small modification that makes assembling the selectorbox a whole lot easyer .
machine a groove for a circlip to hold the bridge in place that goes over the spring
and machine a small recess for the circlip in the cover
Users browsing this forum: No registered users and 139 guests
