Anybody know which way the bevel bearing in the head comes out? Looks like down (away from the bevel cover), but I want to be sure before I force it the wrong way...
Much thanks!
-Jim
Remove this bearing up or down?
blaat!
Re: Remove this bearing up or down?
Hi Jim
this bearing sits in a housing . that housing has a small colller on the bottom so the only way out is down
blaat!
Thanks Eldert. Does the housing come out with the bearing?
joe46ho
Jim, I sent you a lengthy p.m. about this and the other questions you asked, but its still in my outbox. Did you get it ?
Too many projects to list...
12 Ducati singles currently
I've heard that this bearing housing can sometimes be a cause of noise, due to movement. Reportedly, it loses its interference fit in the head.
So, being careful with it might pay. Heat the head before removing the bearing housing. Heat again to refit, and lubricate before.
If you have a mystery top end noise - this could be the cause?
blaat!
Got it Joe. Thanks everyone.
-Jim
-Jim
Users browsing this forum: ranton_rambler and 142 guests
