Since I took the Powerdynamo system off my SCR and put back the points, I will need to replace the old wiring harness. My original one is garbage.
I see some listed on Ebay (Italian-Motorbikes) but the seller tells me that they do not include the headlight wiring - which I really need. Only other source I find is Amici Dello Scrambler but I am not a member.
Anyone know of another source for complete harness or is anyone a member of Amici that would be willing to order one for me?
Source For Scambler Wiring Harness
Teckhardt
1970 450 SCR
Re: Source For Scambler Wiring Harness
The widecase Scrambler wiring harness does not include the headlamp wiring.
The main wires from the main harness connect to a terminal block inside the headlamp. (Part no.0698.38.344)
From there, wires go to the light and ignition switches, the ones to the light switch being soldered on.
I think you will be hard pressed to find a wiring harness different from that sold on e-bay.
I would guess the Amici Dello Scrambler ones will be the same as their parts are usually very close to original specifications.
There is not much wiring in the headlamp, or the whole machine, come to that, so it is quite easy to make up a harness from scratch.
Teckhardt
Amici says theirs includes the headlight wiring if I am reading it correctly.
"Electrical system SCR IGNITION (Contact points) complete wiring including internal headlampsize and color cables ORIGINAL (together with scheme electrical installation in colour) "
The wiring in my headlamp was really a rats nest of previous owners mods. The rest of the harness was so brittle that I would hate to reuse anything.
I guess I could make one but after making a whole harness for the powerdynamo that I pulled out, I am too burned out.
1970 450 SCR
Users browsing this forum: No registered users and 96 guests
