Rev counter mount
Rev counter mount
Postby ranton_rambler » Fri Oct 16, 2026 5:27 pm
I have bought a cheap electronic rev counter and am struggling to find a place to mount it at the moment.
Any photos of how the OEM version was mounted? I think they normally go on the right hand side of the handlebars where the only likely points to pick up are the fork cap or the headlamp side screw.
Re: Rev counter mount
Postby graeme » Sat Oct 17, 2026 2:52 am
What bike Ian ?
Postby ranton_rambler » Sat Oct 17, 2026 7:02 am
My bike is a 175TS which would not have had a rev counter, so I suppose I am looking for how it was mounted on the contemporary sporty versions. Elite or Mach 1 I think.
Last edited by ranton_rambler on Sat Oct 17, 2026 9:16 am, edited 2 times in total.
Postby themoudie » Sat Oct 17, 2026 8:59 am
Mornin' Ian, from a chilly -2°C, but very bright Perthshire.
Attached is an image of a Ducati MK3 250cc, with the accessory tacho mount using the single right hand side bolt for the headlamp shell as it's mounting point.
I'm sure that many moons ago there was a discussion and possible replication thread about this bit of tin work on the forum. So, a wee search using the 'Search' window top right, might prove useful?
Good health, BillR
nalimugmug
Postby nalimugmug » Sat Oct 17, 2026 11:43 am
Any help? On a Mach1
Bob
Postby ranton_rambler » Sat Oct 17, 2026 12:59 pm
Thanks both.
Those seem to be the same type and use fork top cap and headlamp bolt.
I have found a piece of thick alloy plate in my garage so I think I will make something to pick up the fork cap. The electronic unit is quite lightweight so I think it will be ok with a single mount. I will try the unit first though, to make sure it works before putting the effort into the bracket.
PS Bill - about 5C here in the middle of England. Sunny though!
Postby ranton_rambler » Sat Oct 17, 2026 2:03 pm
By chance this Mark 3 popped up in a For Sale ad. Seems to be a different version using the central nut.
I’ll see if that might work better but might obscure the speedometer in the headlamp shell.
Postby ranton_rambler » Thu Oct 22, 2026 6:57 pm
I cobbled some wiring up today and the cheapy rev counter seems to work OK. I'll sort out a proper mount and tidier wiring when I get chance.
It raises a question - now that I can see the engine speed what should the idle speed be on 175? I have just set up by ear at the moment which seems to be about 1500rpm on the gauge.
Postby Duccout » Fri Oct 23, 2026 5:52 am
I don't know what the idle speed should be, but I like mine as low as possible as it gives better gear changes.
Postby themoudie » Fri Oct 23, 2026 9:14 am
Aye Ian,
Ducati engines are no steam engines. So, whilst a slow tickover from a long stroke British single may sound therapeutic, it isn't going to happen with a Ducati single. Besides, how long do you spend at tickover? I understand that the England-shire and Scottish conurbations are getting bigger and the ever increasing 20mph zones, mean it is more likely, but overall the engine doesn't sit there for long.
My 450 , with it's past habits of spitting back through the carb, or blowing it off, makes me set an even tickover, between 1,100 and 1,300 rpm. Yes, I can get it to go lower, but when moving off, with my gearing of a 17t and a 41t, the revs need to be up and above 2,000rpm due to the relatively short stroke and large bore of the engine, coupled with the gearing.
Better off to have the engine running at a junction/traffic lights/roundabout than it coughing and then having to hop off to push the beastie to the side, or give it a swing, in the hope that it'll start first prod, whilst the electric car GT stakes kick off all around you.
Good health, BillR
Users browsing this forum: No registered users and 93 guests
