450 selector box question
Postby graeme » Thu Mar 12, 2026 6:00 am
I took the Scrambler out yesterday to pick up parts for my log splitter.
All good on the way there, and halfway back it stuck in 2nd gear.
The gear lever moved up and down the full distance but wasn’t changing gears.
Felt like the claw wasn’t latching on to the pegs for each gear step.
The it came good again.
I removed the selector box, removed the cover, cleaned the grease out so I can see what was going on.
I think the small light spring that pushes the claw down had moved down partially into the law hole. ?????
Should be a shim / washer under the spring. There is none in this one.
Opinions,,,,??
Main problem is that it works perfectly at the moment.
If it’s not broken I can’t fix it
Re: 450 selector box question
Postby graeme » Thu Mar 12, 2026 6:15 am
Pic
Postby Duccout » Thu Mar 12, 2026 7:04 am
Hi Graeme,
I had the same thing happen to me years ago; I fixed it by fitting a thin shim under the spring (possibly a bevel gear shim). I don't know if a shim should go in there, but it solves the problem.
Postby graeme » Thu Mar 12, 2026 9:23 am
Hello Colin,
I replaced the bronze bushes in the outer and inner case.
I’m sure I put the mechanism back the same way it came apart and didn’t have any shims / washers left over.
(I’m aware that if you pull something apart often enough, sooner or later you will have 2 of them)
Also fitted a new return spring.
I have fitted a shim for the light spring to sit on so it can’t move into the hole (as seen in the picture)
Time will tell,,,,
Postby LaceyDucati » Thu Mar 12, 2026 10:04 am
Hi Graeme
No there isn't supposed to be a spring there, but as you have discovered sometimes it benefits from one. I always fit a 0.3 to 0.5mm shim there when rebuilding boxes. I think the later hinged mechanisms are more prone to this issue, due to the slot, rather than the hole of the earlier mechanisms.
Postby graeme » Thu Mar 12, 2026 7:44 pm
Hello Nigel,
The light coil spring was there but I think it was falling into the elongated hole in the claw ? As in the picture
And not pushing the claw down to let it grab the pegs.
I fitted a.3mm shim between the claw and coil spring
Seems ok now.
The Haynes manual shows the washer / shim, item 25 or 26
Postby LaceyDucati » Thu Mar 12, 2026 10:40 pm
Hello Graeme
Sorry my typo...I meant to say washer not spring :-) Rushed off my reply, without reading it back!
Of course there is meant to be a spring, however no factory parts book I've seen shows the washer. I will check for sure when I get back to the workshop next week and check the Haynes manual. Maybe the Haynes manual took the diagram from a late parts book (which is a rare item). That said I've never found that washer in any original box I've stripped. Albeit they could benefit from it!
Bevel twins with selector boxes, also occasionally suffer the same issue.
Postby graeme » Fri Mar 13, 2026 12:38 am
Page 41 Haynes manual, item 25
Postby Jordan » Tue Mar 17, 2026 11:40 am
Some parts lists show the shim, others don't.
An added item by the factory at some stage?
