I have checked the system over, not that there is much to check as it is only a few simple wires, but all appears to be in order. Here is a question though for those who have the STK-169D system fitted: did you run the green wire to the battery earth, or ground it on the frame? The instructions say that the green wire goes to the battery, but I have ground it with the other earth wires on the earth point provided on the frame.
Ignition Woes
IanHood
Re: Ignition Woes
Hi Colin,
I ran mine to the battery however, assuming the battery negative terminal is connected properly to the frame on yours, I can’t see why it would make any difference.
Users browsing this forum: No registered users and 63 guests
