2mm axial play on shaft of Ducati ignition...
Roland
Postby Roland » Tue Jul 15, 2025 1:36 pm
...doesn't seem right.
I know, i have to take it apart.
But what is the problem here, missing spacers, or is it normal?
350 Scrambler, 1973
Re: 2mm axial play on shaft of Ducati ignition...
Postby Duccout » Tue Jul 15, 2025 5:53 pm
Normal!
Colin.
Roland
Postby Roland » Wed Jul 16, 2025 3:33 am
Thanks!
350 Scrambler, 1973
Roland
Postby Roland » Wed Jul 16, 2025 6:39 am
I am very interested in the mechanics behind this assembly.
Especially why it is normal and why it is working this way.
Cross section of it would be very nice, something like this one attached.
Found this drawing somewhere but cannot remember.
It is very nice, perhaps new stuff based on 3D model.
Is more of 2D / 3D stuff available?
Roland
350 Scrambler, 1973
Roland
Postby Roland » Fri Sep 12, 2025 12:55 pm
Another question on this ignition, please:
Where is the advance generated?
Transducer, pickup, or some centrifugal force device behind it?
Could not find an answer in drawings and manuals...
Thanks again
350 Scrambler, 1973
Postby graeme » Fri Sep 12, 2025 9:27 pm
My understanding is that the faster the rotor spins past the coil the more it advances the spark up to the required 28 degrees (for 450)
Postby Jordan » Fri Sep 12, 2025 11:16 pm
CDI ignition advance changes according to engine speed.
The trigger coil generates higher output when going faster, making the ignition point sooner.
The output is AC sine type waveform with a pulse once per revolution.
Advance behaviour can be changed by number turns of trigger coil wire, strength of magnet, distance between magnet and coil.
Lots of things you can play with. :)
Roland
Postby Roland » Sat Sep 13, 2025 9:54 am
Thanks!
350 Scrambler, 1973
Postby Jordan » Sat Sep 13, 2025 10:26 pm
Sometimes a mechanical advance mechanism is used with CDI, such as on Honda CT110.
I don't know why they do that, but the trigger device can be arranged to provide a nearly static ignition at all speeds, and the advance action is done mechanically.
Roland
Postby Roland » Mon Jun 01, 2026 8:39 am
I am thinking of replacing the 50+ year old ignition by a Sachse.
Simple question:
will the Sachse-pickup tolerate this 2mm play?
Thanks!
350 Scrambler, 1973
Users browsing this forum: No registered users and 149 guests
