Cam support bearing removal?
Hiya9612
Postby Hiya9612 » Wed Jan 29, 2025 9:19 pm
I need to replace the bearing in the cam support cover (which is running rough) but it's stuck fast. There's lots of references on here to removing a reluctant cap but nothing that I can find about the bearing.
I have put the assembly in the oven at 175C for a few minutes to no avail and have found a suggestion that welding a nut to the bearing inner race and using a bolt to "push" the bearing out can work.... but my welding isn't up to much and I'm not sure how the aluminium would respond to the pressure from a bolt. So before I take it to an engineer (if I can find one) does anyone have a clever suggestion?
Phil
Dave354
Re: Cam support bearing removal?
Postby Dave354 » Wed Jan 29, 2025 9:29 pm
Hi, I used a blind bearing puller. Heated the cap up on the bbq, then fixed it to the bench. The puller is a slide hammer type and it just came straight out. Bearing replacement was by heating the cap and dropping the bearing in from the freezer.
Hope you find a solution
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Postby LaceyDucati » Wed Jan 29, 2025 10:34 pm
Will most likely just drop out if heated up.
Hiya9612
Postby Hiya9612 » Wed Jan 29, 2025 10:58 pm
LaceyDucati wrote:Will most likely just drop out if heated up.
Hi Nigel.
Any suggestion for temperature/duration? I did 10 minutes @175°C (bearing pointing downward in a metal cylinder) not a millimetre of movement.
You'll recall all the other bearings in that engine, it wouldn't surprise me if it had Loctite 638 (or similar) keeping it in.......
Phil
Postby Duccout » Thu Jan 30, 2025 8:20 am
Hi Phil,
You can fashion a puller out of an expanding wall fixing, or I have made one in the past with a nut and bolt and a couple of pieces of aluminium sheet that jam the bolt behind the bearing, but the easiest way is to buy eBay item no 226524357987 Inner Bearing Puller Set for about £16; I have used this many times on engine bearings and it works like a charm. Money well spent.
IanHood
Postby IanHood » Thu Jan 30, 2025 10:44 am
I would certainly try the oven at a higher temperature and for a lot longer first. I don't know any domestic oven that would get hot enough to harm the alloy housing.
IanHood
Postby IanHood » Thu Jan 30, 2025 10:45 am
...and always advisable to do this when your better half isn't home :lol:
Postby themoudie » Thu Jan 30, 2025 11:03 am
Having used the "Rawbolt" method, the heat method, 100°C for 20 minutes, once the thermostat has come up to temperature in a fan oven and both work, the latter if some "glue" has been used! :evil:
Colin's suggested eBay purchase is also available as eBay lot number: 235439808242 and for a fiver less, but apparently from a Dunstable seller as well, using an alternative eBay account?
As for waiting until your "better half" has left the building! Not in this house and the fan oven is quick at bringing the casting/bearing up to temperature. To be honest, I suspect that an air fryer would do the job just as well, providing that the thermostat and timer were reasonably accurate and you could have that out in the workshop, then do your jacket potato after! :D
Postby LaceyDucati » Thu Jan 30, 2025 1:04 pm
If you've tried 175C then it's most likely stuck in with loctite! plenty of other good suggestions have been made, which should work.
bendik
Postby bendik » Thu Jan 30, 2025 5:01 pm
I just pulled my cam cover off when the engine was hot and the bearing was stuck on the camshaft. Easy ;)
Users browsing this forum: No registered users and 58 guests
