Couple of Questions
Couple of Questions
Postby Duccout » Tue Nov 05, 2024 5:16 pm
What is the difference between wide-case and narrow-case heads? I think that I remember that the narrow-case has a different squish angle? I have tried a search here but nothing comes up.
Secondly, those using Amal carbs, where do you get your rubber spacers (between carb and inlet flange) from? Do you use those from a specific British bike?
Thank you,
Re: Couple of Questions
Postby blethermaskite » Tue Nov 05, 2024 6:31 pm
Colin, I don't think there is any difference (could be wrong) I think the squish difference you suggest is between 250 and 350 heads but I have never actually measured it, pretty sure Nigel referred to this in some post on here somewhere. I never use those rubber inlet spacers....in my opinion they are just an air leak waiting to happen, Cheers George
Postby George » Tue Nov 05, 2024 6:44 pm
I believe Jesus Guzman stocks rubber inlet spacers
George S Norfolk UK
Postby blethermaskite » Tue Nov 05, 2024 7:33 pm
Colin, sorry I misread in your post, what is the 'rubber spacer' between the Amal carb and the inlet flange? Assuming you mean flange type Amal's? I thought you meant the rubber spacer between the std Dellorto carb inlet spigot and the head (which I won't use) With Amal's I use either an alloy inlet spacer or my own preference is a tufnol spacer (thermal barrier). Amal 'flange' carbs...monobloc's concentric's GP's TT's are all subject to greater or lesser degrees of having easily distorted flange's and a rubber inlet spacer will just make the situation worse.
Not sure if that's the answer you are looking for?
Cheers, George
Postby Duccout » Tue Nov 05, 2024 9:31 pm
Hi Both Georges,
Thank you. The reason I ask about the rubber manifold spacer between Amal carbs and the inlet flange is that my 250 carb is 27mm and the only spacer that I could find of 27mm was the one that Jesus Guzman sells, but it is very thick and squishy and I can flex the carb back and forth, indicating that it could be leaking air. I would prefer a tufnol type but I could not find any in 27mm.
Postby themoudie » Tue Nov 05, 2024 9:37 pm
Aye Colin,
Same as George, if you are refering to the AMAL flange carbs and not the MKII Concentric?
Always used a Tufnol spacer between the carb and the cylinder head. Link to the Tufnol website below, if you want to know more? Followed by a link to the "Classic Bike Shop" who supply Tufnol spacers, with a 32mm bore. I am sure there are other alternative suppliers. ;)
Tufnol_website or Direct Plastics Tufnol web pages Direct_Plastics_Tufnol_info
As with most engineering materials these days, you pay for the correct grade of material, in this case Tufnol "Whale", or "10G/40".
Classic_Bike_Shop_Tufnol_AMAL carb_spacer_32mm_bore
This link below, to the AMAL website, with regard to tightening the flanged carb to the cylinder head should be heeded!
Installing-AMAL-carburetters
Hope this helps answer yours and others questions.
Postby George » Wed Nov 06, 2024 9:28 am
Hi Colin, I bought a sheet of 8mm thick tufnol and made a heat shield spacer. I have more than I will ever use and can cut a piece off if you want to make one. Will post or if you want to put some miles on the Enfield pop over to Canvey.
George S Norfolk UK
Postby Duccout » Wed Nov 06, 2024 1:12 pm
Hi George,
That is really kind of you. PM sent.
Postby Eldert » Wed Nov 06, 2024 3:23 pm
Hi Colin
the 350 cc narrowcase Sebring has a diff angle squish band and i think some of the very late Mototrans 350 widecases to
40 versus 45 degree angle is my memory serves me correct
Postby Duccout » Wed Nov 06, 2024 4:27 pm
Hi Eldert,
Thank you.
