chain sizes for early bikes
Postby Bevel bob » Sat Nov 02, 2024 4:27 pm
Having some issues working on a 1960 Italian Bike . the 420 chain i bought seems to be about half a mm to short in the pitch , after about 5 pitches the chain rides up on the sprocket. Any idea whats happening ? seems like the sprocket pitch is 12mm and chain 12.5 mm or 1/2". Do early italian bikes use a metric size ??
Re: chain sizes for early bikes
Postby themoudie » Sun Nov 03, 2024 11:28 am
Aye Bob,
Does the attached link below help you to sort out your chain size requirement?
Motorcycle_chain_size_dimensions
I am not ofay, with 1960's (assume Motobi?) chain/sprocket relationships. However, I would suggest that you get on the blower on Monday and have a word with "The Chain-man" link:
The Chain-man
In my experience, he has been very helpful, with supplying chains for the 450, whilst I obtain my sprockets from Nigel. Maybe a call to Talon sprockets?
I hope this helps, with the conundrum.
Andy Higham
Postby Andy Higham » Mon Nov 04, 2024 12:31 pm
As far as I know there is no chain made with a 12mm pitch. The only metric pitches are 03B = 5mm, 04B = 6mm and 05B = 8mm
Postby George » Mon Nov 04, 2024 12:51 pm
I have owned Moto Guzzi, Mondial, Ducati and MZ all had imperial chains 1/2"
George S Norfolk UK
Postby Bevel bob » Mon Nov 04, 2024 9:15 pm
Not got to the bottom of this yet ! , could be a rogue sprocket ?
Postby George » Mon Nov 04, 2024 9:41 pm
Have you checked pitch on front sprocket
George S Norfolk UK
Postby Bevel bob » Tue Nov 05, 2024 6:41 am
Not yet George, some dismantling needed and we wanted to ride the bike a few times before the winter layup . Plenty of serious issues ,Forks totally worn out, wrong and worn carb, brake linings badly worn,,clapped out chain, draggy clutch with wrong parts, no battery box. motor solidly blocked with carbon , blown incorrect exhaust flange , leaky valve ,broken valve adjuster, wrong points .wrong timing, lights part working, faulty condensor, glazed bore or stuck /wrong rings, Worn out primary gear. Center stand an inch too long,Wrong gearing, raised when it should have been std or lowered, Nothing much then !! Looks really good though.(all fur coat!)
Postby George » Tue Nov 05, 2024 10:58 am
Hi Bob,PM sent
George S Norfolk UK
Postby Bevel bob » Tue Nov 12, 2024 5:56 am
After much experimental fiddling with ignition timings and modifying the advance unit the Catria now starts and feels responsive. Once the non sealing piston rings are either bedded in or replaced the bike will be viable. Had to back off the timing about 10 degrees from standard , I think these early bikes were expected to run on 72 octane or similar which needed a lot of advance. Todays fuel burns a lot faster i think .
