Speedo drive repair
IanHood
Speedo drive repair
Postby IanHood » Sun Aug 04, 2024 8:26 pm
I have to replace the ‘tang’ on the veglia speedo drive on my 450. I have a new ‘tang’ but can anyone advise how the drive comes apart so I can replace it?
Re: Speedo drive repair
Postby Duccout » Mon Aug 05, 2024 9:41 am
Hi Ian,
It is ages since I did this job, but I think that there is a wire circlip on the inside that has to be prised out.
IanHood
Postby IanHood » Mon Aug 05, 2024 1:14 pm
Thanks for the steer Colin, I'll take a look and see what I can find. :)
Postby ranton_rambler » Mon Aug 05, 2024 6:55 pm
Is it like this? I cleaned it all off, and then was able to carefully knock the staking on the bronze ring back until the tang disc could be wriggled off. Reverse the process for the replacement.
Good reminder that I probably ought to take it out of the forks and re-lube it.
Ian P
IanHood
Postby IanHood » Tue Aug 06, 2024 11:26 am
Problem solved. For anyone else doing this the tab comes off easily for replacement by hooking out the retaining clip with a small screwdriver. See picture.
Users browsing this forum: Google [Bot] and 59 guests
