centre stand woes
Re: centre stand woes
Postby blethermaskite » Thu Jul 18, 2024 9:38 pm
So using the formula of educated guess I cut 35mm out of each leg of the centre stand and welded it all back together again......complete success :D .....instead of the back wheel being 3 inch's of the ground its now 3/4 of an inch, and the bike for the first time in 50 years is now quite easy to pull on the stand.......why did I not do this years ago :roll:. Thanks all for advice.
Postby themoudie » Thu Jul 18, 2024 9:50 pm
Aye George,
Nouse wins again! ;)
Slainte, Bill
Postby graeme » Fri Jul 19, 2024 2:19 am
Good news !!!!
Postby George » Fri Jul 19, 2024 6:57 am
Good news George. That's you sorted for another 20 years riding.
George S Norfolk UK
Postby blethermaskite » Sat Aug 03, 2024 1:55 pm
As a new installment of all the above.........after all the messing about sorting out my centre stand problem the bl**dy spring has just broken :x so seems a bit hard to get one, does anyone know if the narrow case spring is the same as the wide case one I can get a narrow case one but not the other, or does anyone know the dimensions of either, I can't measure mine because it has broken a couple of times over the years and I have just managed to bend out the next loop to keep it working so its shorter than std......which is why it has just broken again :roll:.
Cheers, George
Postby graeme » Mon Aug 05, 2024 6:22 am
Hello George.
Measure the spring on my ‘74 Desmo center stand.
Wire diameter is 2.5 mm
Diameter of coil is 15mm
36 coils
132 mm long with the stand down. (Not including the loops at each end)
Hope this helps
Postby blethermaskite » Mon Aug 05, 2024 9:29 am
Perfect! Thanks Graeme :) .
nalimugmug
Postby nalimugmug » Mon Aug 05, 2024 11:03 am
Maybe here?
http://www.mdinaitalia.co.uk/SKU044012040.html
http://www.ducaticlassics.com/parts/175 ... and-stands
Here's a pic from a Mach 1 different from above
Postby themoudie » Mon Aug 05, 2024 11:15 am
Aye George,
If MdinaItalia's offering is for the V-twin rather than a single and there are differences in the srpring wire diameter, number of coils, length etc, then maybe a trawl through this selection might be helpful to you and others on the forum looking for replacement springs?
Sprimgmasters_UK
Dave354
Postby Dave354 » Mon Aug 05, 2024 6:50 pm
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Users browsing this forum: Google [Bot] and 81 guests
