Electrex World cdi box mounting
Re: Electrex World cdi box mounting
Postby Duccout » Wed Jul 31, 2024 11:13 am
Could be......
Postby Eldert » Wed Jul 31, 2024 7:58 pm
Hi Graeme
that black box says 2 cylinder hall effect
Postby Duccout » Wed Jul 31, 2024 8:47 pm
Christ Eldert, we must call you Hawkeye.
Postby themoudie » Thu Aug 01, 2024 12:18 am
G'day Graeme,
I assume that you have ordered the "Hall Effect CDI Ignition System" from Nigel? Link below:-
Hall-effect-cdi-ignition-system-p-1459
You should note the following in red print, below the image and details of the product package:-
Please note the new CDI unit in this kit does NOT have a mounting point and therefore when fitting the unit will need to be secured to the frame gusset in some way, probably via a large tie wrap. We are working with Electrex for a solution with a small bracket but this may take some time. If you have any questions regarding mounting the unit please contact us.
That would appear to answer your question and confirm that a bit of closed cell foam and a couple of zip ties might have to serve temporary duties for the time being! ;) Unless you fancy a wee bit of sheet alloy (road sign material), or stainless steel, flexing and bending from your repetoire of precision and "bush engineering"?
Postby graeme » Thu Aug 01, 2024 12:28 am
Hello Bill,
Ok I hadn’t seen that red note.
It’s not in the delivered paperwork.
I can sort a better solution than a cable tie.
Eldert,
I did notice the 2 cylinder marking on the CDI box.
Here is a pic of the kit I bought from Lacey Ducati.
It shows the same CDI box markings.
Postby Duccout » Thu Aug 01, 2024 6:53 am
Ah, so all is explained......
Dave354
Postby Dave354 » Thu Aug 01, 2024 8:59 pm
Hi, I have used a very high bond (vhb) double sided adhesive pad… here is the link:
https://www.ebay.co.uk/itm/254491435473 ... media=COPY
If both surfaces are grease free it sticks like the proverbial to an army blanket….. the ‘gel’ of the material also provides some vibration damping!
Just a suggestion.
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Postby graeme » Fri Aug 02, 2024 12:39 am
Thank you Dave
Users browsing this forum: No registered users and 84 guests
