Jim, your blood is worth bottling.
Thank you for your efforts keeping old singles alive.
I found a AA in good condition if you still need.
Wide Case Parts Manual. ?
Re: Wide Case Parts Manual. ?
graeme wrote:Hello Jordan
Item 40 from Haynes manual
Haynes' item 40 is Ducati part number 0608.16.270, according to the parts list at ducatimeccanica.com site mentioned earlier.
Details on the drawings and list could be clearer, but I gather that part number has dimensions 17.2 x 24 x 1 mm, quantity one off.
There is a similar washer, item 22, part no. 0400.16.120 of 17.2 x 24 x 0.5 mm, quantity two off.
I get the impression that either of these washers could be used according to need when shimming.
IanHood
Jim,
I’m not actually a web designer (I run a public relations agency) but I have built a large number of web sites (some quite complex) over the years, primarily using the WordPress content management system, which is open source (i.e. free) and widely supported. I can probably help but it depends what you want to do. Do you want to create an entirely new front end to the site or to try and fix the broken bits in the existing site?
JimF wrote:I built the website long ago using Microsoft “Front Page.”
It was simple to use for amateurs like me. Microsoft got out of web design software business and support for the Front Page program disappeared.
If any forum member is a web designer I’d like to hear from you.
