Timing issue
IanHood
Timing issue
Postby IanHood » Sat Jun 22, 2024 12:31 pm
I'm trying to figure out if I'm doing anything wrong with timing this 450. See picture below I have aligned the dot on the crank with the idler that drives the oil pump (which you can't see in the picture) but I have a couple of questions:
1. Although the way I have aligned the bevels will result in their corresponding dots meshing correctly, the piston is at TDC when this picture was taken and they are not completely meshed - is that correct?
2. The book that I'm using says that on 450 models, the scribed line on the timing idler gear should be used - I can't see any such scribed line???? What am I missing?
Thanks in advance.
Re: Timing issue
Postby Eldert » Sat Jun 22, 2024 1:54 pm
Hi Ian
there are more then 1 type small bevel gears . the dot should be at the 11 o clock position
some gears have the dot at the keyway so the 12 o clock position
mrkprsn
Re: Timing issue
Postby mrkprsn » Sat Jun 22, 2024 2:27 pm
On my 200 there are two timing dots on the lower gear. I don't know if the 450 is that way.
Re: Timing issue
Postby Duccout » Sat Jun 22, 2024 3:35 pm
Hi Ian,
What position is the lower bevel vertical shaft in? It has to match up with the corresponding half-shaft of the upper bevels, and that position is set by the camshaft position - ie the cam lobes must be at 4 and 8 o'clock and the slot in the end of the cam must be vertical when the piston is at TDC; if you have to rotate the cam to get the shafts to match up then something is wrong.
IanHood
Re: Timing issue
Postby IanHood » Sat Jun 22, 2024 3:54 pm
Thanks Eldert. So I THINK what you are saying is that what have looks right - with the piston at TDC the dots on the small bevel gears will be at 11 o’clock?
Eldert wrote:Hi Ian
IanHood
Re: Timing issue
Postby IanHood » Sat Jun 22, 2024 3:57 pm
The head is off at the moment Colin but yes, I am setting the cam lobes at 4 and 8 for reassembly.
Duccout wrote:Hi Ian,
Wolf
Re: Timing issue
Postby Wolf » Tue Jun 25, 2024 12:16 pm
Hi Ian,
this is what I've found in my 450 motor - the scribed line is clearly visible in the picture.
Wolf
IanHood
Re: Timing issue
Postby IanHood » Tue Jun 25, 2024 12:32 pm
Thanks Wolf. Strangely my timing idler definitely doesn’t have that scribed one but it’s entirely possible it was swapped out at some point over the years. In many ways it doesn’t matter too much - I have an Electrex ignition system from Lacey Ducati on this machine and I can set the timing at 28 degrees BTDC with the idler in either position.
Users browsing this forum: No registered users and 85 guests
