What rings do I need, weird 250.
Rbranst
Re: What rings do I need, weird 250.
Postby Rbranst » Tue Nov 14, 2023 4:11 pm
Double D - thanks a lot - that helps. Interesting thing about my piston is it sure looks a LOT like MC pistons I see. But the bottom is machined and doesn't look like the other forged MC pistons I see on the bay.
I have been keeping an eye out for MC Ring sets, they seem to pop up often. I would need a 74 + .060" or a
Set of .090 on there right now - Actual MC Supply NOS. - Could I file these down? they would be .762 too wide. Price is right at $18.
1968 Ducati 250 Scrambler (US)
1972 Mototrans 250 Road
Rbranst
Postby Rbranst » Tue Nov 14, 2023 7:38 pm
Bottom of my piston.
Bottom of typical MC piston
Postby Eldert » Tue Nov 14, 2023 9:12 pm
the bottom of my MC piston looks the same as the bottom of your piston .
its machined to .
i think you need a set of 0.080 rings
Rbranst
Postby Rbranst » Wed Nov 15, 2023 1:03 am
Thanks for the feedback that helps a lot!
Postby double diamond » Fri Nov 17, 2023 5:18 pm
MC catalog shows .003”-.005” piston clearance, .006-.008” for racing. Measure at the bottom of the piston skirt with a feeler gauge. Aldo, the bore in your cylinder wasn’t properly honed, if it was honed at all. Verify the parts are good before investing in a ring set.
Nick
Postby Nick » Wed Nov 22, 2023 4:13 am
I had Venolia make pistons for my BSA and Triumph. These are modern pistons with modern rings and they'll make them to whatever finish size, comp. ratio you want.
Put a Mikuni on it!
Users browsing this forum: Google [Bot] and 63 guests
