Good morning-
I have two narrow case Ducatis- the Mach I has a complete superpractic with cover and screw. The Scrambler has a superpractic with a cover, and an in-correct screw that doesn't quite thread in all of the way- obviously wrong thread. The screw from the Mach I does successfully thread into the scrambler.
The parts manual states the screw is part number 0180.54.560 and is a 3ma x 3 ... but all 3mm screws in my hardware store are 3mm x .5 pitch, which seems too fine of a thread- as the screw from the hardware store does NOT thread into either superpractic. I think the correct screw seems to be a more-coarse thread.
Can anyone give me more information on this? I guess I COULD try to re-thread the part to accept the 3mm .5 pitch screw... but I would rather not.
SIncerely,
Bob Woolner
Hillsboro New Hampshire USA
screw for cover of superpractic throttle
Re: screw for cover of superpractic throttle
3MA metric thread: coarse is 0.5 pitch fine is 0.35 pitch
George S Norfolk UK
bw_nh
Good afternoon-
Yes, 3mm is usually .5 pitch, but… I don’t think that that is what the screw is, on the superpractic. At least, not on either of my two.
Mine both appear to be a coarser thread than .5.
Should it be 3mm by .5 pitch? Should I re-tap both of mine?
Sincerely,
Bob Woolner
Hillsboro, New Hampshire USA
Sincerely,
Bob Woolner
Cover and screw for sale US Ebay. Maybe seller will sell screw only https://www.ebay.co.uk/itm/183382387903
I could check mine tomorrow if you want.
George S Norfolk UK
bw_nh
Good evening-
Yes, I saw that- but wonder if THAT screw is 3mm by .5 pitch , or something odd, like what I have.
IF it is supposed to be .5 pitch, then I might as well use a tap, and buy a stainless-steel screw for 40 cents at my hardware store. I Have the cover... I just need the correct screw.
SIncerely,
Bob W
SIncerely,
Bob W
mrkprsn
Mine is a 3mm x 3mm fine MA fine thread
Users browsing this forum: A.I.M, Google [Bot] and 46 guests
