Almost there
Dan C
Re: Almost there
Postby Dan C » Mon Mar 20, 2023 6:31 am
That's a brilliant job Ian, another one rescued from the knackers yard - well done!! :)
And good on you for getting it going with a springer head, better to have it out on the road and putting a smile on your dial than languishing on the workbench waiting for parts!
Dan
IanHood
Re: Almost there
Postby IanHood » Mon Mar 20, 2023 8:24 am
Thanks Dan. The only issue with the springer head is that I will now have to put up with with the occasional person say, "yeah, but it's not a real one is it..." :)
I did think about slapping on a Desmo version of the cam end block but I'm not sure it will even fit on a springer head.
Dan C
Re: Almost there
Postby Dan C » Tue Mar 21, 2023 6:51 am
Those rivet counters can be a bore at times....lol....but its only a temporary state of affairs - a desmo head will turn up one day!
Dan
cooperplace
Re: Almost there
Postby cooperplace » Thu Mar 23, 2023 1:41 am
That looks amazing. It looks like my old bike. Good luck starting it, mine could be awful on a bad day.
be nice, I'm not very bright.
IanHood
Re: Almost there
Postby IanHood » Thu Mar 23, 2023 8:25 am
Actually starting is remarkably easy. Although it has a springer head right now, I am running it without a decompressor but it is using the Electrex CDI ignition system from Lacey Ducati and I'm running a Dellorto PHBH 30AS carb. It's first or second kick every time (which is just as well for someone who has buggered both knees skiing).
Re: Almost there
Postby graeme » Thu Mar 23, 2023 11:12 pm
Nice job restoring your 450.
I’m sure you will enjoy it
cooperplace
Re: Almost there
Postby cooperplace » Fri Mar 24, 2023 11:53 am
IanHood wrote:Actually starting is remarkably easy. Although it has a springer head right now, I am running it without a decompressor but it is using the Electrex CDI ignition system from Lacey Ducati and I'm running a Dellorto PHBH 30AS carb. It's first or second kick every time (which is just as well for someone who has buggered both knees skiing).
You're lucky or you've done something I couldn't.
Last time I tried to start my 250 (strong white spark, lots of fuel), I gave up after 45 minutes of kicking.
Last time I tried to start my 350 (strong white spark, lots of fuel), I gave up after 45 minutes of kicking.
And yes, i know the technique.
Re: Almost there
Postby Duccout » Fri Mar 24, 2023 12:21 pm
Something wrong with both! They should start easily.......
IanHood
Re: Almost there
Postby IanHood » Fri Mar 24, 2023 12:32 pm
That was my thoughts exactly, definitely something not right.
cooperplace
Re: Almost there
Postby cooperplace » Sun Mar 26, 2023 10:56 am
Duccout wrote:Something wrong with both! They should start easily.......
Yes I know there's something wrong, the problem is I don't know what it is. It's probably me. But my Honda has a much better starting technique: you press the button.
Users browsing this forum: No registered users and 146 guests
