Ducati Forza rear Brake master cylinder
Fasttrack
I am looking for a Ducati Forza rear Brake master cylinder , if you have one would be interested in buying , or does anyone know if can still buy a replacement new one , please let me know if can help
Re: Ducati Forza rear Brake master cylinder
Hopefully, Jon Pegler will come along soon, but in the meanwhile ...
When the AJP rear m/c on my Vento failed, I followed Jon's advice and replaced it with a Brembo unit
Here's what Jon said. Note what he wrote at the end about Forzas:
"Most early Ventos had 12mm Brembo master cylinders fitted front and rear, with the AJP cylinders being fitted later.
I've never had to repair an AJP unit, as I've always had Brembo cylinders on my bikes. Jesus Loriente at Recambio Usado in Spain sells some AJP repair kits, although whether they will fit a Vento I am not sure.
Failing that, the 12mm Brembo unit fitted to the Parallel Twins was identical to the Brembo cylinder fitted to the Vento and they come up for sale fairly often, so should not be too hard to find.
I've also fitted the larger 15mm rear master cylinder from a Moto Guzzi to a couple of Forzas without any problems. They usually come with the low fluid sensor in the filler cap, but I just discarded that in favour of a plain one."
HTH - and thanks, as always, to Jon.
Craig
Craig
Fasttrack
Thanks craig for post
I have found a original old stock ajp master cylinder and have purxhased , hopefully problem may now maybe solved with brake failing
Best Regards
Best Regards
Return to “Classifieds: Ducati Parts/Accessories wanted or for sale”
Users browsing this forum: No registered users and 106 guests
