Cure for Tippy Scrambler Side Stand
Alex450Jupiter
Postby Alex450Jupiter » Mon Nov 21, 2022 4:44 pm
My '74 450 Scrambler side stand is virtually useless in most real world settings... very easy to tip the bike over. It seems original and undamaged. Length from pivot to shoe is 12-3/4". Is there a solution, other than carrying a hockey puck around with me?
Re: Cure for Tippy Scrambler Side Stand
Postby Duccout » Mon Nov 21, 2022 6:34 pm
I had a 450 mk111 and the side stand worked OK, so I wonder what is different on the Jupiter? I am assuming that the bike leans over too far?
Alex450Jupiter
Postby Alex450Jupiter » Mon Nov 21, 2022 7:34 pm
Yes, leans too much. Not much of a force would topple it over onto the side-stand side.
Postby Duccout » Mon Nov 21, 2022 9:10 pm
Hmmmm, so maybe the forks are longer on the Jupiter? I believe that the rear shocks are longer? Would it be possible to weld a section into the stand to make it longer?
Postby Ventodue » Tue Nov 22, 2022 3:13 pm
Alex450Jupiter wrote:Yes, leans too much. Not much of a force would topple it over onto the side-stand side.
Sounds like you've got the wrong stand ;) . Here's mine ...
I don't see a listing in the parts book for a 450 SCR side stand, so have to assume it was the same as for the 250/350 SCRs. For which there are two models listed, differentiated only by the diameter of the mounting pin (14 or 16mm).
However ... Ducati Vintage Store sell the same stand for all 3 models of SCR. So I rest a tad confused ...
Alex450Jupiter
Postby Alex450Jupiter » Tue Nov 22, 2022 4:03 pm
Ventodue wrote: … Here's mine ...
Could you kindly measure the length of your stand, from centerline of the pivot axis to the end of the shoe? Thank you. Mine is 12-3/4 inches.
Postby Ventodue » Tue Nov 22, 2022 5:05 pm
Pretty much the same - see photo. Must be someut else ....
Postby Ventodue » Tue Nov 22, 2022 5:08 pm
Ventodue wrote: Must be someut else ....
Not rotating too far forward, is it?
Postby Ventodue » Tue Nov 22, 2022 5:18 pm
Reference photos of 3 other bikes for you. So you shouldn't be leaning more than this ..
Postby George » Tue Nov 22, 2022 8:36 pm
Have you checked that pin on stand has not been bent.
A common problem as stand is not made to take weight of rider sitting on bike or kickstarting. I had to alter mine.
George S Norfolk UK
Users browsing this forum: No registered users and 72 guests
