Yes - it is a dual single shoe brake, one side there is maybe a very fine crack and on the other side of the hub the drum way have been welded.
First of all - it works very well - only when cold/have been sitting for a while it tends to screech but the retardation is always impressive.
What do you think - should I do anything? Or just drive on?
Many thanks and kind regards
Wolf
...there is maybe a hairline crack and a welding seam in the front brake drum
Wolf
Re: ...there is maybe a hairline crack and a welding seam in the front brake drum
never seen a repair like that
I certainly would not be happy to keep on using this......if this started to come apart while you were out on the road the result could be fatal, I know these particular brake drums are now getting expensive and a bit hard to get but how much value do you put on your life .......this is just my opinion others may differ.
Wolf
George,
thank you for your worries -this is the reason for my post that I am in doubt wether it is safe to ride it. The previous owner was aware of the cracks and told me so.
I've just ordered a "Dye Penetrant Inspection" -system. I will let you know what I'll find.
Just say no to crack
Wolf
Wolf
Ducadini
Didn't even know it was possible to weld that without damaging the aluminium exterior.
Could it be that the bike has been left sitting for a while in a damp environment and the brakeshoe left an "imprint" ?
If I find a damaged drum, i'll cut it to see how the iron inner and alu outer are "connected".
ciao
ducadini
ciao
ducadini
Wolf
...here are the results from my crack inspection:
The one where I was very certain that it might be a crack is maybe not, visible in the first picture.
The one which looks like a welding seam did show a respone, but this is maybe caused by a not complete removal of the red agent.
I will skim the brake drums on a mill and will redo the crack detection test.
Wolf
Wolf
really interested to see the result of the skim test. I have been were you are with this before only on a Very expensive 4ls racing brake drum.
you can put new liners in . already replaced 210 and 230 mm liners with turned down car drums .
180 mm is a very common diameter for car drums . i think VW fox has them to
We’re the cast iron drums cast into the hub or shrunk in to the alloy originally ?
Wolf
Hi Eldert,
this is an information of great value! You just put the hub on the lathe, remove the old brake drum and shrink a machined VW sparepart into the hub? Sounds promising! The will be the last option, if the skimming of the brake drum will not work in the intended way.
Although I have to admit, that shrinking parts into another is always very exiting for me...
Many thanks
Wolf
Many thanks
Wolf
Wolf
...the machining is done, tomorrow I hope to do the crack inspection.
Users browsing this forum: No registered users and 96 guests
