Duccout wrote:Hi Blaine,
It never does any harm to re-check the ignition timing. I wonder if a worn A/R unit could be causing your idle problems? The spark plug will depend on how you are riding, but generally for a Monza I think that you should be running with a B6HS.
Keep us informed.
Jordan wrote:That's a nice clear photo of your installed points.
What points gap are you using?
Did you set it at the max open position?
Users browsing this forum: graeme and 240 guests
