So - I got my Mk3 running on the lift, fueled from a UV bottle.
Replaced tank and seat, fitted fuel lines, put on my riding jacket and rolled the bike out of the shop. Poured a gallon into the tank, prepared to fire it up and do a test ride, only to see gasoline dripping from both petcocks.
A quick look confirmed that the fuel is oozing out from inside the cocks.
I imagine that after 50+ years, at least the last 20 without being used, the rubber/cork/whatever is used inside these has perished. So I need to replace both petcocks. Before I go to eBay and risk buying something there, does anyone know a good source in the US for replacements?
Romomoto
Dripping cocks
nalimugmug
Re: Dripping cocks
Here are some antibiotics for your issue:
This will give you a pointer. Or is it the fibre washer between body and tank leaking?
https://www.ebay.co.uk/itm/Ducati-Singl ... 4514338429
Bob
Bob
Romomoto
Re: Dripping cocks
Thanks, Bob. I confirmed that the leaks are from inside the petcocks.
Re: Dripping cocks
You may be able to replace the rubbers inside the petcocks.
Romomoto
Re: Dripping cocks
Duccout - I don't see how to disassemble these. I'll have a look again.
nalimugmug
Re: Dripping cocks
I replaced my seals a while back.
Put the main block in a vice with protective jaws with the nut upper most-remove the operating lever, then undo the nut-there is a spring behind so be
wary of this.
Remove this rotating component, and you can then access the duff seal.
Remove this seal carefully without damaging any mating surfaces.
Install new seal-I seem to remember there is/are small locating dowels for the seal.
Be careful not to cross thread the rotating block when you put it back in.
wary of this.
Romomoto
Re: Dripping cocks
Thanks - but these have no nut. That's why I can't figure out how to disassemble them.
nalimugmug
Re: Dripping cocks
If you post a picture maybe somebody may be able to assist.
Bob
Bob
Romomoto
Re: Dripping cocks
Here's what the petcocks look like:
450duke
Re: Dripping cocks
Try bevelrubber.com.au and check under rubber products, there is a listing for singles petrol tap seals
Hope this helps
Hope this helps
Users browsing this forum: No registered users and 120 guests
